How to Make a Hair Dryer - DIY Homemade Hair Dryer
1,865
18
5
Published
Introduction: How to Make a Hair Dryer - DIY Homemade Hair Dryer
About: Mix of original & cool videos: Life-hacks, DIY, Mechanics & Tools, Cooking tips, Crafts ideas and much more!
❄ SUBSCRIBE HERE ➜https://www.youtube.com/subscription_center?add_us...
❄ ALL VIDEOS HERE ➜ http://www.youtube.com/user/fixitsamo/videos
❄ FOLLOW US:
FACEBOOK ➜ https://www.facebook.com/fixitsamo
PINTEREST ➜ https://www.facebook.com/fixitsamo
GOOGLE+ ➜ google.com/+fixitsamo
Always happy to hear from you! Your comments, shares and all other interactions are very welcome.
Thanks for watching!
Step 1:
Make the fan: Cut a 5" diameter plastic circle. Install a Mini Universal Drill Chuck. Cut the lines. Heat to bend.
Step 2:
Cut 4 pieces 1/4" x 2" long (Foam Board) and glue them to a High Speed DC Motor (DC 6V-24V 30000 RPM). Install the Drill Chuck/Fan to the motor and insert it in a 2" x 2" x 1-1/2" ABS Sanitary Tee.
Step 3:
Nichrome Resistor Wire 7.5M / AWG24 / 0.5mm: Make 20 spirals.
Insert Terminal Blocks Strips Wire Cable Connectores.
Step 4:
Cover the 2" Spigot x 1-1/2" Hub ABS Reducing Bushing with Aluminium Foil Tape.
Glue the Nichrome Wire using an Automotive Grade RTV Sealant Temperature Range Up To 204° C.
Step 5:
- Make a hole in a 1 1/2" ABS Cap Hub and install the Power Adapter.
- Connect both red wires coming from the Nichrome Resistor and the Power Adapter Jack to the red switch.
- Connect both red wires coming from the DC Motor and the Power Adapter Jack to the green switch.
- Connect all black wires coming from the DC Motor and Nichrome Resistor to the Power Adapter Jack.
- Make holes in a 2" ABS Cap Hub and glue it to the back of the hair dryer.
Step 6:
For cool air, press the green button. For hot air, press both red and green buttons.
Watch the video:
Vidéo en français (French):
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    5 Discussions
    What a good gadget! we can save money! I think that green is represent of cool. so,for cool air,press the green button can be better ;D I used Google translate to repair my English logic mistakes,what a boring work! : (
    Yes the green button is for cool air...Sorry I made a mistake. Thanks!
    I'm sure this is what MacGyver would do in a hair emergency. well done.
