How to Make a Hand Spinner Whith a Hard Drive
2,428
11
Posted in PlayToys
Introduction: How to Make a Hand Spinner Whith a Hard Drive
About: Dad, Maker, biker, trekker, I like sciences, technology, martial art and wild.
Hello everyone! In this instructables I will show you how to make a hand spinner with a hard drive.
The principle of the hand spinner is very simple: an axis, a ball bearing, and 2 or 3 weight of the same mass. The hard disk provides the axis and the ball bearing, for the weight, we will improvise.
You can also find all the steps and a demo of the result in video at step 8 "bonus".
Let's go!
Step 1: Components and Tools Needed
Tools:
- screwdriver (The type of screw changes according to the manufacturer of hard disk but generally it is about Torx screws)
- a drill
- a glue gun
Materials:
- hard disk (No SSD of course :-) )
- 2 bottle caps
- 3 Threaded screws or 3 pieces of threaded rod
- 12 nuts
Step 2: Disassemble the Hard Drive
To start, we will disassemble the hard drive.
- First remove all screws on both sides of the hard drive.
- Then remove the disc cover with a flat screwdriver.
Now you have to disassemble the reading head in order to free the disk.
Bonus:you can retrieve the neodymium magnet. I love this magnet, he's really too cool!
The most difficult part is usually this one: you have to bring out the axis which is pressed in the Chassis of the hard disk.
- To get out axis, I use a screwdriver and a hammer, it's a bit radical, but it works well!
- Finally, remove the screws that secure the disc to the axis and remove it.
Step 3: Preparation of the Disk
Now we will prepare the disc for hanging weights.
We will divide the disc into 3.
- For this, with a protractor, make 3 angles of 120 ° and make marks with a pen.
You normally have a mark at 0 °, 120 ° and 240 °.
Step 4: Drilling the Disk
In this step, we will drill holes in the the disk so we can hang weights.
Caution: Hold firmly disk when you drill and wear gloves because the disc will quickly heat!
- Drill 1 hole on each mark we made in the previous step, about 1 cm from the edge
Step 5: Hang the Weights on the Disk
Now we will hang the weights on the disk.
- If threaded screws are used, cut the head of the screws.
-Screw 2 nuts onto a threaded rod, pass it through one of the hole in the disc, then screw 2 more nuts.
Repeat this twice.
- Now, reattach the disk to the axis.
Step 6: Hold It!
Now we will make the part to hold it.
- Cut the outline of one of the 2 bottle caps.
- Drill the bottom of the second cap. Insert a screw (recovery on the hard drive)
- Fill the glue cap and then close with the piece of the first cap.
- Allow to dry.
- Screw your bracket
Step 7: Rotate!!!
Here's your and spinner is over! You can improve it, there is something to do! 2 disks, cut branches in the disk ...
have fun!
Step 8: Bonus: All Steps and Demonstration in Video!
If you liked this project, subscribe to my youtube channel!
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    3 Comments
    Disassembled an old IDE drive I found on my drawer, but the axis has no bearing... it seems to me lightly magnetic though. Well, will have to open a 2.5" one and see if I have better luck :P
    I am definitely going to have to look inside some of the broken electronics around here. There seem to be all sorts of treasures.
    Absolutely! The only problem is to store them while waiting to need them... it piles up quickly! :-)
