How to Make a Healthy Popcorn
237
Posted in FoodSnacks-and-appetizers
Introduction: How to Make a Healthy Popcorn
About: I am author of the best selling book, “The Power of Personality Types in Love and Relationships,” a wellness coach, an instructor in various forms of martial arts and meditation, a former kickbox...
Directions for Cooking Healthy Popcorn:
Cooking popcorn in a Pot:
  • Put 2 – 3 tablespoons of coconut oil to thinly cover the bottom of the pot.
  • Heat on medium flame.
  • Test the heat of the oil by putting in 1 or 2 kernels in the pot. When they pop, you know its ready. (Don’t change heat from medium.)
  • Once ready, put enough kernels to cover the bottom of the pan. (About 2/3 cup)
  • I also like to add Rosemary and Himalayan Pink salt into the pot
  • Cook at medium to high temp with the pot covered until they have almost stopped popping.
Screen shot 2014-03-08 at 2.25.02 AMTo To Cook in an Air Popper is simple, just put the kernels in the bottom up to the fill line, then turn on. Add coconut oil or raw butter after with the ingredients below: healthy popcornWest Bend 82416 Air Crazy 3.5 Quart Corn Popper
Use healthy organic heirloom ingredients. (This insures it is non-GMO and has no chemicals) Organic heirloom, non-gmo popcorn. Heirloom means it is from a particular ancient grain that has not been hybridized. These taste better, pop more and doesn’t put the hull in your teeth and gums. I like “Tiny but mighty” popcorn because it is: Whole grain and kosher certified, gluten free, no pesticides. Although they are not certified organic, they only use organic practices and no pesticides and are non-GMO certified. And it is an open pollinated heirloom corn. With not cross-contaminated with any other corn including any GMO so there is no risk of GMO. -
healthy popcornTiny But Mighty Heirloom Popcorn ~ virtually hulless Non-GMO popping corn
- Himalayan Pink salt - Over 82 minerals in this salt and is actually health for you rather than table salt which is terrible for you. This is also way better then sea salt for one because it is away from many of the chemicals in sea water like mercury. healthy popcorn
Salt Pink Himalayan No Chemicals Non-gmo Organic Halall Kosher Fine Grind (.5mm) (5 Pounds)
- Organic Cold Pressed Coconut Oil - There are many health benefits to consume especially for your brain, organs, digestion and more.
Nutiva Organic Coconut Oil, Virgin, 29 oz
- I also put rosemary and sometimes chocolate from the homemade chocolate video that I made. Screen shot 2014-03-08 at 2.20.59 AM
Simply Organic Rosemary Leaf Whole Certified Organic, 1.23-Ounce Container
- You can also just add coco butter and cocoa powder to the coconut oil when it is cooking in the pan.
What to Avoid:
- Avoid all popcorn that does not say Non-GMO certified and always get organic to avoid this, since over 90% of corn in the US is GMO. - Avoid all microwave popcorn. See some of the very unhealthy ingredients found in microwave popcorn in this picture:
Slide12 - Even if the nutrition label on your favorite popcorn brand reads "0% trans fat," you may want to take a closer look. Any hydrogenated oils on the label indicate the presence of trans fats. The loophole? If it's less than 0.5 percent, food manufacturers don't have to post trans fat percentage on the label.
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
