Introduction: How to Make a Holiday Wreath
Today I will be instructing you how to make a festive holiday wreath using inexpensive materials.
Step 1: Materials
- Wicker Wreath
- Bush-ale of Fake Flowers and or Leaves
- Wire
- Glue Gun
- Ribbon Wide
- Ribbon Thin
- Scissors
- Seasonal ornaments or objects
A Crafty Mind
Step 2: Bow Making Process
Because the Bow is the centerpiece of your wreath you want to start by crafting that first. Now you want to unravel the wide ribbon from its spool so you have one long piece of ribbon. Taking one of the ends, wrap it around your finger making a button shaped circle. Then start twisting and looping the yarn remembering to alternate sides each time so it inst to become disproportional. When that process has been completed you want to take a small to medium piece of the wire thinner the better and wrap it through the button and then twisting it closed. Do not cut off the extra hanging wire this will be used to attach the bow to the wreath.
Step 3: Assembly
When decorating a wreath you want to decide if its going to be half decorated or fully decorated. I prefer the half decorated wreath because it tends to not look as crowded or competing with the wreath itself. For this purpose I will be demonstrating a half decorated wreath. Now taking your bow you must first choose a side to secure it one. When decided separate the now two pieces of wire looking them through the wreath and again twisting the ends securely. After that has been completed its time to add the seasonal ornaments. You don't want to glue them in just yet your only going to be placing them in for now. You might decide later you want a flower of pumpkin positioned in another spot so this allows for easy removal and placing.
Step 4: Finishing Touches
After you are pleased with the look of the wreath you now want to glue the objects in place. All you need is a little dab of the hot glue because if you use too much it will tend to look messy and there will be thin glue strings all over the wreath. When the glue is dry its now time to take the thinner ribbon, cut a good sized piece of the ribbon and loop it through the top part of the wreath and then trying a bow or not connecting the two ends. This will be what hangs the wreath to the door.
Step 5: Further Production Help
For further help during this craft I uploaded a link to my video where I actually go through this process.
http://youtu.be/dXw45xvTVqs
or
go to youtube and type in my movie with music
Halloween Decorations Contest
