3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Japanese Bokken
Here I describe the method for making a bokken, which is a Japanese wooden sword.
The skill level required using this method is relatively low. A more challenging option would be to do this only using hand-tools.
Take nothing for granted and keep safety as the most important aspect of the project. Make sure you are comfortable with the use of all the tools you use.
Step 1Overview
Contents:
Basic dimensions
Making the Boken
Terminology
Notes & Cautions
Dedication
I suggest that you borrow or buy a boken before you start, so you can get the feel and see the details of what you are making. It will also help you set up the curvature of the one you create. Hopefully you are already training with one at some level, so you have an understanding of the balance it should have.
Ganbate kudasai (Japanese for good luck)
204 comments
1-40 of 204next »
May 4, 2009. 1:38 PMmetdrummer says:
Excellent article! I'm building two bokken right now out of ebony, blood wood, and american holly. I don't practice any sort of kendo, so I plan on these being ornamental. Thanks for the instructions!
Oct 3, 2009. 10:34 PMmetdrummer says:
Here are my finished bokken based on your instructable. Like I said earlier, they're made of ebony, bloodwood, and american holly. I wasn't entirely sure if I wanted to make the tsubas, but I had a lot of bloodwood left, so I thought "what the hell." Handles are wrapped in white and black suede. I'm more than happy with the way they turned out, and it's all thanks to you!
Feb 11, 2012. 8:26 PMliLightaura says:
OMG I WANT GIVE ME please :) oh wait i mean PLZZZZZZZZZZZZZZZZZZZZZZZZZZZ cause extra z's r better :) lol but seriously i want
Apr 20, 2010. 3:55 PMKeira_Yagami says:
Wow.... O_O that is beautiful! I'm so going to have to make one for my boyfriend, well another bokken that is. Seeing as I've already made him 3 ^-^'
Apr 20, 2010. 5:27 PMmetdrummer says:
Thank you so much :D
Jul 25, 2011. 8:15 AMIkkalebob says:
Great instructable! I made mine out of one plank of oak. Here it is:
Sep 7, 2011. 6:16 PMDynames4 says:
I'm trying to find a way to successfully use bamboo to make a bokken... So far, no success. Do you have any techniques that might make this possible? Thanks
Oct 17, 2011. 8:41 PMzjohnson6 says:
what you want to do is make something else entirely its called a kendo shinai stick and they're made by taking strips of bamboo and binding them at the base middle and with a rubber or synthetic ferrule at the tip they're easy to make and very durable
Jun 21, 2011. 4:43 PMhottamaleindustries says:
I don't know why I didn't look this up first... I tried making some before and I put in so much more effort to model it after my katana... This is so much simpler and more elegant looking
May 18, 2011. 9:13 PMRiptide100 says:
Could someone please explain to me how to mount the Tsuba on this bokken? I dont undestand the instructions given here. I also looked on another instructable specifically for a Tsuba, but he just glues it directly to the bokken. PLease help, thx :)
Jun 1, 2011. 8:05 PMcommanderzhao says:
take the tsuba, and gasket maker (you can get it from a do it best store)
then slide on the tsuba, and apply the gasket maker, and smooth it out with a
popsicle stick, and..... voila!! you mounted it!!!
May 8, 2011. 7:10 AMFoo Ninja says:
I'm about to try making one
for exercise out of summer boredom
anyways
what's the different between:
If you cut a wider piece into a bokken
you bend it with clamps/ heated watter?
will it affect the hardness?
I want to make the easy one since i never did any works with woods and any tools like that (including the saw or routing)
Apr 18, 2011. 4:13 PMmeburnfire says:
How would you do this using only 1 piece of wood?
Feb 23, 2011. 7:39 PMRiptide100 says:
This instructable is amazing!! Im busy following this and making 3 bokkens for cosplay/display purposes. i will post pictures of the process and upon completion :)
Feb 17, 2011. 7:21 AMTethera says:
hi, hmmm i don't know quite how to ask but, is it possible could i make a sheath for my bokken? because i really would like to train seriously but all the trianing swords i have made were crummy and way to light weight to get some serious training in. what kinds of wood could i use that would be best for making a bokken. and also what would be the bokken's length? or could it be just made longer with the same steps?
but how hard would it be to make one without the actual thing with you? cause i can't buy one or barrow one ^_^;;
Sep 30, 2010. 7:54 PMDELETED_kage_no_akiri says:
(removed by author or community request)
Sep 28, 2010. 9:06 AMninjakoi says:
what are the measurements in?
Jul 26, 2007. 1:01 AMmae says:
hiya, im just starting with kendo, so as i dont see any information about shinais, could you tell me if its possible to make one bokken lighter than normal?? (problably with another kind of wood of something?) i just want it for training at home (i borrow one for class) so i dont mind if it doesnt look real enough (just b safe). Thanks for your advices, you did a great job. x x
Aug 2, 2010. 12:43 PMBodygard1117 says:
you can rout out some of the hardwood from the middle of the blade before you put it together and fill it with pine or even balsa. Ive seen it done on pool sticks and they take a pretty hefty beating.
Oct 31, 2007. 2:13 PMWurdBendur says:
Do you think drilling holes into or through the blade and handle would reduce the weight enough and not make it too weak?
Jan 17, 2009. 10:16 PMDELETED_ironchopstix says:
Jan 18, 2009. 11:52 PMWurdBendur says:
That's what I figured.
Sep 14, 2008. 9:26 PMryanator says:
nice pic (wissle)
lol
Feb 3, 2008. 12:17 AMfinfan7 says:
first of all; light enough for what? and secondly, that depends on wood type, grain direction, whether it is made from two pieces like the one in this instructable or one piece like a normal one, and also on its intended use.
Feb 7, 2008. 10:24 PMWurdBendur says:
I was referring to the post above about making it lighter for kendo. I don't know how light it would need to be or what kind of construction would make it work. I was just trying to suggest that putting some holes in it could make it lighter while noting that it would weaken the blade.
Feb 12, 2008. 3:15 PMfinfan7 says:
I see your intent now. It is an interesting idea but kind of counterproductive. If it is for single training then heavier is better because you get more exercise and it would be closer to the weight of a real sword. If it is for sparring then the last thing you want is a bokken more likely to break . (splinter+eye=very very bad) And although lighter can be a good thing, if it is too light relative to that of your partner then you will be able to move faster but it will be harder to block anything you cannot sidestep.
just to sum up this whole sequence:
you can (faster, looks kooler)
you shouldn't (breaks, breach in tradition, and not enough excercise)
Dec 16, 2009. 5:04 PMClodester says:
Just a note, a bokken are made intensionally heavy, or at least heavier than a true katana in order to train the individual to be over qualified so to speak. The idea being that if you are skilled with a weighty piece of wood, you'll be more than proficient with a light strip of carbon steel.
Lighter alternative would be bamboo which is often used for practice swords
Oct 1, 2008. 10:19 PMCamisado says:
To quote you:
I agree on most of it, but I don't think drilling holes to a Bokken makes it look " kooler ", to me it looks more like " garbage " :P
Jan 18, 2009. 3:23 PMfinfan7 says:
You are allowed your opinion. I made no claim that everyone would think it is cooler, only that I thought it might look cooler. I wouldn't do it because I am a stickler for tradition in the martial arts. If you don't think it looks cooler don't do it. There is no need to make a comment with the specific intent of insulting me. We on instructables encourage constructive criticism among Makers and proffesionals, not baseless insipid conjecture from children who don't like others' opinions.
Jan 19, 2009. 1:17 AMCamisado says:
Heyheyhey, I'm not insulting you in any way, I'm just voicing my opinion. If you like your Bokuto drilled, then you can do it for all I care, I'm not insulting your opinion, I'm just voicing mine.
Jan 19, 2009. 11:18 AMfinfan7 says:
Your word choice displays a disdain for my opinion, which would be why I took offense. But it's okay.
Jan 20, 2009. 1:35 AMCamisado says:
Good. I'm glad we both understand.
Dec 3, 2009. 3:23 PMTrogdayton says:
If you were to use just one length of wood instead of two... that'd be pretty much the same right? You'd just have to bend, not glue? Or am I totally wrong?
1-40 of 204next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:TTF
