Introduction: How to Make a Lamp
Picture of How to Make a Lamp
For this project I used the X-Carve CNC machine by Inventables. The software I used to program the CNC is called Easel which is also by Inventables. So all my steps for this project are based on using a CNC machine. You don't need a CNC machine to do this project, you can use a scroll saw.
All of the .svg file can be found here: https://www.inventables.com/projects/lamp
For this project I used Wenge which was 1/8" thick. The base is made from 3/4" Wenge and 1/4" Maple reveal. The white film i used to diffuse the light is called "Light Diffuser Film".
Step 1: Step 1 - Layout
Picture of Step 1 - Layout
Laying out the Wenge pieces is a little tricky. The 1/8" Wenge pieces that come form Inventables are 6″×12″. So I stacked four pieces vertically on their long edge and the 5th piece to the left with the short side on the x-axis. See picture. In Easel you may need to move your lamp pieces around to make them fit in the 6″×12″ rectangles. I used double sided tape to hole my pieces down.
Step 2: Step 2 - Carve #1
Picture of Step 2 - Carve #1
Load the Lamp file to cut out the lamp sides, top and bottom pieces. This file uses a 1/16" bit. Double check your material thickness. The pieces I received from Inventables were not consistent.
Step 3: Step 3 - Carve #2
Picture of Step 3 - Carve #2
Without moving anything, load the Lamp Voro file to cut the Voronoi pattern in the sides, top and bottom pieces. This file uses a 1/8" bit.
Step 4: Step 4 - Be Careful!!!
Picture of Step 4 - Be Careful!!!
If you use double sided tape, be careful when prying the pieces off. Take your time. I used a putty knife and it worked out great.
Step 5: Step 5 - Cut the Light Diffuser Film
Picture of Step 5 - Cut the Light Diffuser Film
Cut the light diffuser file into rectangles. Make sure you over size it so that it goes past the voronoi patter. I used a craft tacky glue and it had a hard time sticking. I would recommend using something else.
Step 6: Step 6 - Glue Up
Picture of Step 6 - Glue Up
Now this is where it gets tricky. At first, I tried gluing everything together…that didn’t work. So I ended up gluing one pieces on at a time. Just take your time and make sure everything is tight so you don’t have any gaps were light can shine through.
Step 7: Step 7 - Magnets
Picture of Step 7 - Magnets
It will be easiest to glue in the magnets before you glue on your last side. I bought some 3/4" magnets at my local craft store. I only used 3 magnets.
Step 8: Step 8 - Base
Picture of Step 8 - Base
For the base of the Lamp, I used a 3/4" piece of Wenge cut into a 6″×6″ square. Load “Lamp Base” in Easel. This will cut the hole for the light fixture and a slot for the cord. You may need to adjust the cut outs if you use a different light fixture.
Step 9: Step 9 - Glue in Light Fixture
Picture of Step 9 - Glue in Light Fixture
I used epoxy to glue in the light fixture. I only glued in the metal pieces, not the cord.
Step 10: Step 10 - Maple Reveal
Picture of Step 10 - Maple Reveal
I used a pieces of maple to act as a reveal. I cut it into a 5″×5″ square. There is a 2" hole in the center, which is enough room for the light fixture. I also recessed the other magnets into this pieces. Again I used a 3/4" magnet, so you may need to adjust the holes in the file to fit your magnets. Load “Maple Base” and cut away.
Step 11: Step 11 - Sand, Sand......Sand
Picture of Step 11 - Sand, Sand......Sand
Before sanding, check and see if you have any gaps in your joints. If you do, mix up a little epoxy and add some Wenge saw dust to it and fill and gaps with this mixture. I used a flat sanding block when sanding my lamp. I didn’t want to use a orbital sander as it was to risky and I didn’t want to break any of the voronoi pieces.
Step 12: Step 12 - Finish!
Picture of Step 12 - Finish!
I used a polyurethane finish and applied one coat.
Step 13: DONE!!!!
Picture of DONE!!!!
Put a light bulb in, attach the lamp to the base and plug it in. Enjoy!!
Step 14: Video
I made a YouTube video about this Lamp, check it out.
AnnaB137 (author)2017-10-08
very nice, I think there should be some patterns that you can make be hand or something with out all the big tools that are not here where I live
TerryS3 (author)2016-03-29
Wenge is dangerous. Check out Wikipedia; .
In short, the dust affects the skin and sinuses/lungs like poison ivy, and splinters tend to get infected. Be more careful than usual with dust and splinters, ventilation and gloves are your friends.
Once shaped, sanded and poly-coated, there should be no danger from the made project unless it's broken.
Other fine-grained woods are less hazardous, though Wenge does have a beauty all its own.
FlorinJ (author)TerryS32016-03-30
Also acc. to wikipedia it's an endagered species.
I suppose you could achieve the same effect with a more common wood (white oak or birch) and a dark staining.
blueaxe (author)2016-03-29
Well done! Has a Medieval quality I like very much.
AtifH3 (author)2016-03-28
Very nice, the video puts everything in perspective very nicely!
NickL4 (author)2016-03-27
Nice!
JamesW33 (author)2016-03-26
It reminds me of the redstone lamp from the game Minecraft, and I really like that fantasy/game-like aesthetic.
Gutoboranga (author)2016-03-25
Great instructable! It looks great, by the way
Thank You!
waylightcreate (author)2016-03-24
Very nicely done.
Thanks!
hbridge88 (author)2016-03-25
Super gorgeous and very well crafted!
WildmanProject (author)hbridge882016-03-25
Thank you, I appreciate it.
Very nicely done.
mlawing (author)2016-03-24
Looks great!
WildmanProject (author)mlawing2016-03-24
Thank you!
Looks great!
About This Instructable
30,692views
418favorites
License:
Bio: I have a little DIY YouTube channel. My channel will feature DIY project that I do around my house. Everything from making a twin bed ... More »
More by WildmanProject:How to make a LampHow to make a CenterpieceHow to Make a Wood Mirror Frame
Add instructable to:
