Step 2Materials List and Tools
Tank and Plumbing
- 1 32 Gallon Plastic Trash Can
- 2 3/4" PVC Ball Valves
- 5 1-1/2" hose clamps
- 1" ID washing machine hose (length will vary depending on your setup)
- 1 washing machine hose hook end
- 32" of 11/4" corrugated sump pump hose
- 3/4" diameter PVC pipe (around 3 ft. of length)
- 1 3/4" diameter PVC 45 degree turn (or a "T")
- 2 PVC threaded adapter - 1" male thread to 1-1/4"female thread
- 2 PVC adapter, 1" male thread to 1-1/4" diameter
- 1 Threaded hook with a nut (for holding up the end of the tank outlet hose)
- 4 lengths chain (rated 80-100 lb), length depends on your particular hanging situations
- 1 length of the same chain 24" long
- 4 wood screw threaded hooks (rated 80-100 lb)
- 4 1-1/4" ID rubber washers (or make your own from used bicycle inner tubes)
- 2 1-1/2" metal pipe thread nuts
- 1 12" x 20-3/4" plywood, reinforced with metal, at least at the corners
- Top from a qt. yogurt container
- popsicle stick
- 1 machine screw
- small piece of velcro (both male and female)
- 1 piece of PVC pipe, 3/4" or 1", cut wide enough to sit in the top of your washer basin
- 1 threaded rod (#6 or #8 thread)
- 1 lock nut for each of the load sizes your washer has (mine has 4)
- 2 nuts and 2 washers to fasten the threaded rod to the pipe
- 1 piece of 2" diam ABS pipe 8-10" long
- Electric Drill
- 1-5/8" hole saw
- Dremel Tool
- Utility Knife
- Hack Saw
- Teflon Tape
- 2 pipe wrenches
- PC-7 Multipurpose Waterproof Epoxy
- PVC Cement
- Twist Ties
Add Comment
