How to Make a Lego Crossbow That Shoots
Introduction: How to Make a Lego Crossbow That Shoots
Step 1: Get Two 1x16 Bricks With Holes in Them and Put Tiles Over 11 Studs on Each Brick.
Step 2: Attach Them.
Step 3: Get Two 1x6 Bricks With Holes in Them and Place 7 Technic Connectors in the Holes Shown.
Step 4: Connect the 1x1 Plate to the Underside of the First 1x6 Brick
Step 5: Bring the Pieces You Made Before and Connect Them As Shown in the Next Picture.
Step 6: Connect the Bricks.
Step 7: Get the Following Pieces: 2 1x4 Plates, 2 Technic Connectors, 2 1x2 Bricks With a Hole in Each, 2 1x2 Bricks With a Axle Passageway in It.
Step 8: Connect the 1x4 Plate Onto the 1x2 Bricks in the Order Shown.
Step 9: Connect the Technic Pieces.
Step 10: Bring Your First Piece Over.
Step 11: Connect the Pieces You Just Made Onto the End of the First Piece As Shown With the Axle Passageway on the End Hole of the First Piece.
Step 12: Get the Pieces Shown Below.
Step 13: Connect the Axle and the White Piece.
Step 14: Connect the Technic Connector to the Black Piece.
Step 15: Connect the Axle Into the Black Piece.
Step 16: Bring Your First Assembly Over.
Step 17: Connect It Exactly As Shown.
Step 18: Get the Following Pieces, the Axle Is 14 Studs Long But Can Be Replaced by 2, 7 Stud Long Axles.
Step 19: Connect the Axle (or One of the Axles) to the Black Piece and Put the Bushings On.
Step 20: Bring Your First Piece Over.
Step 21: Put the Axle All the Way Into the First Assembly. (If You Are Using Two Axles Then Just Put One in Halfway)
Step 22: Put the Same Pieces on the Other Side of the Axle.
Step 23: Get the Pieces Shown.
Step 24: Connect Them in the Order Shown.
Step 25: Get the Following Pieces and Connect the Technic Connectors EXACTLY AS SHOWN. (the Gray One Does Not Have to Be Gray)
Step 26: Connect the White and Gray Pieces.
Step 27: Connect the Red and White Pieces. This Is What You Should End Up With.
Step 28: Bring the First Assembly Over.
Step 29: Connect the Handle As Shown... Make Sure It Is on the Bottom Level.
Step 30: Collect One 1x6 Plate and Two 1x2 Plates With Only One Stud in the Middle.
Step 31: Connect Them As Shown So That Half a Stud Space Is Showing on the End.
Step 32: Put It in So That the Trigger Can Only Go to a 90 Degree Angle As Shown in Next Picture.
Step 33: Connect the Piece.
Step 34: Get a Thin Rubber Band.
Step 35: Connect It As Shown.
Step 36: Pull One of the Strips of Rubber Band Under the Front of the Gun As Shown.
Step 37: Get a Regular Rubber Band and Connect It As Shown in the Next Picture.
Step 38: Connect the Regular Rubber Band As Shown.
Step 39: Pull the Rubber Band Back Onto the Top of the Trigger and Use a 1x1 Brick As a Bullet. Pull the Trigger and It Will Shoot About 10 Feet. HAVE FUN!!!
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
