3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A Little Switch and Potentiometer Box for Your Arduino
Having cobbled together loads of Arduino circuits and always found myself poking switches and potentiometers through cardboard I thought it was time to produce something a little prettier. So here is how to make a lovely little box to hold 5 potentiometers and 3 switches. (along with some software to make it work)
A simple video of spinning dials, causing them to spin on screen as well:
Step 1Parts & Tools
Parts & Tools
A few items required. Most are easily sourced hobby electronics items.
Acrylic Chassis: Several choices here
  • scroll saw - you can download a scroll saw pattern (03-POTB-ScrollSaw Pattern (A4).pdf or 03-POTB-ScrollSaw Pattern (letter).pdf). Glue it to some 3mm Acrylic and cut it out.
  • your own laser cutter - download the parts outline (PP-POTB-Acrylic Cut Parts.eps or 00-POTB-Acrylic Cut Parts.cdr). Cut them in any 3mm sheet stock
  • purchase a precut set - a mini kit for this project is available (here) - this includes the laser cut pieces as well as the required nuts and bolts ($25 Free Shipping to the USA and Canada)
Nuts & Bolts:
  • 3mm x 10mm bolt (x8)
  • 3mm x 15mm bolt (x14)
  • 3mm nut (x30)
Electronic Items:
Tools:
  • Screwdriver (Philips)
  • Wire Strippers and Crimpers
  • Needle nose Pliers
5 comments
May 7, 2010. 5:06 PMrobotjam says:
I am in the process of building this switchbox and was wondering why you chose the three on-on (SPDT) switches when the schematic shows that only one side is being used. Wouldn't  some simple on-off (SPST) switches work for this?
May 11, 2010. 8:01 AMrobotjam says:
Also I have added three momentary normally open pushbutton switches and a couple led's just to make it look cooler and was wondering how to adjust the programming and the desktop _POTB_SwitchWatcher to show these changes. Thank you
May 3, 2009. 5:30 PMReCreate says:
This is like what i always wanted to do! Awesome!
Dec 20, 2008. 5:05 PMcheft says:
Great work! Clean job and nicely presented. What software did you use to make the Patterns?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
408
Author:oomlout
