Introduction: How to Make a Long Loom Board for Weaving Scarf
Picture of How to Make a Long Loom Board for Weaving Scarf
My daughter asked me to make her a loom board for weaving scarf. So, I made this long loom board for her from a left-over plywood from a previous project.
This loom is very easy to make and you can store it in a corner of your room after finishing your work. Please see the scarf woven by my daughter in the picture above using this board
Step 1: What You Need
Picture of What You Need
  • 4 feet long and 12 inches wide plywood board.You can use any left-over board lying at home
  • A Dremel Rotary tool or any such equipment for drilling holes
  • 1-1/2 inch size nails about 34 pieces (Keep few extra)
Step 2: Measure and Mark
Picture of Measure and Mark
  • The total length of the board available with me is about 48 inches long.
  • After leaving one inch on both sides, mark lines on both sides so that the inside distance is 46 inches.
  • The width of the board is 12 inches. Mark the center on both lines earlier marked
  • Now we will mark the position of nails over the board.
  • The proposed width of the scarf is about six inches. The number of nails should be in odd numbers, so We will have 17 nails on both ends
  • From the center mark the nail positions at a distance of one cm between them.This means we will have 8 nails on each side of the center nail.
  • Using the Dremel Rotary tool, make small holes on the nail positions. These drilled holes will help us in easily driving the nails at the required location
Step 3: Drive Nails and Finish Board
Picture of Drive Nails and Finish Board
  • Now you can easily drive the nails through the drilled holes on the board.
  • Make sure the nails are firmly driven into the board. Clean and finish the Long Loom Board
Step 4:
Picture of
My daughter has used this board to weave a kid's scarf which you can see in the above pictures.
Please see the following instructable on how to use this board for weaving scarf
https://www.instructables.com/id/Weave-a-Kids-Scar...
About This Instructable
597views
12favorites
License:
Bio: I like to make things more simple with easily available resources. My favorite quote: A human being should be able to change a diaper, plan ... More »
More by antoniraj:Home-made Incubator From Reclaimed Desktop Computer CaseHome Remedy : Papaya Leaf Oinment for Muscle Pain and Twisted JointsSore Throat Lozenges and Decoction With Plectranthus Amboinicus Leaves
Add instructable to:
