3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Lynny - A DIY Lensbaby!
  • last photo ←
DIY Lensbaby - The Lynny - Similar Results - WAY Cheaper
IF YOU LIKE THIS, PLEASE SUPPORT IT BY GOING TO THIS LINK, PLEASE!
http://kck.st/uGivd8
This DIY project is made after a Lensbaby, but is built completely different. It’s made of only parts of an extension tube and macro filters. It is similar to the Lensbaby Muse, but more similar to the original Lensbaby, because of the images having a blue glow around bright whites and silvers in the photos, and the fact that the images aren’t that sharp and have a “dreamy” soft focus look to them.
The build is pretty simple. You just have to have the right parts to do this project, which if you are into macro photography, you should have the parts.
Parts you'll need:
Extension tube for your SLR camera
Macro filter set (+1, +2, +4, and +10)
A UV filter with same threads as the macro filters
Adjustable pipe clamps
Electric tape or any other strong flexible tape
An SLR body
Step 1Starting off
Starting off
To build this, you want to take your extension tube and use the smallest (shortest) extension tube piece, and the camera mount and the lens mount pieces, and you want to screw all three of them together (mine comes in different pieces, a camera mount piece, a lens mount piece, and different size parts, 1, 2, and 3, going from smallest to biggest.)
Then you want to use electric tape (or any other tape that will do a good enough job) and you want to make 1 1/2 inch pieces of tape, just keep cutting them until you get about 8-12 (educated guess), and you want to use those to point vertically (pointing up) around the extension tube pieces.
See picture for how it should look.
4 comments
Nov 2, 2011. 8:19 AMtylercard says:
Nice work, and I'm impressed by the results!
Oct 29, 2011. 11:51 PMzsmith17 says:
Honestly your not saving very much money by going this route. the lensbaby muse is $150 retail - with your average extender being around $80, macro filter kit being $30 and a UV filter being $10-15. While a really neat build I don' t really feel that it is all that cost effective. also instead of electrical tape I would go with a vacuum hose or some kind of silicone hose for longevity. The silicone might be a better choice as the vacuum hose is far more rigid. you could also add in the flexibility of the lensbaby control freak with a few more mods. seriously though very cool hack if you can find the parts on the cheap
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:CameraTester
