How to Make a Marble Cannon
Published
Introduction: How to Make a Marble Cannon
The marble cannon is meant to hit a target that is 2 to 5 meters away in distance and one meter off the ground in height.
Step 1: Step 1: Gather Materials
    - One 50x50 cm block of wood
    - Two pieces of PVC pipe
    - Two rubber bands
    - Two one and a half inch pieces of wood and two one half inch pieces of wood
    - Two nuts and bolts
    - One piece of angled wood
    - Many nails
    - 2 Wooden dowels
    - 3 Metal pieces
    Step 2: Step 2: Asemble the Pipe Together
    - Measure out one foot of PVC pipe and cut it
    - Take a wooden dowel and slide it into the PVC pipe then screw it into the pipe
    - To hold the rubber bands there needs to be a zip tie near the bottom of the PVC pipe
    - The rubber bands will be connected to the screw and a latch
    Step 3: Step 3: Assemble the Two Pieces of Wood to the Base
    - Cut the base on one side an inch and a half to each side
    - Take the one and a half inch pieces of wood and place them where the cuts are
    - Take two nails on each side and drill them in
    - Then take the half inch wood and staple them in the middle of the base. When doing this, leave a half inch between the two pieces of wood in the middle
    Step 4: Step 4: Assemble the Pipe to the Wood
    - Cut a twelve inch PVC pipe
    - Put a wooden dowel in the PVC pipe for stability
    - Drill two nails into the end of the PVC pipe
    - Take two nails and drill them into the PVC pipe but not all the way
    - Put metal on the PVC pipe to latch it to the two thicker wood pieces with two nails on either side
    - Then take the angled wood and slide it in between the half inch wood pieces
    Step 5: Step 5: Final Steps
    - Drill a metal piece into the middle of the twelve inch PVC pipe with two nails
    - After the base and the PVC pipe is finished take the one foot pipe and slide it into the piece of metal that was just placed
    - Then adjust the angle wood to the angle that is needed
    Step 6: Step 9: Calculations
    - Figure out the three angles that were needed for the trials
    - Then, figure out the time through the time calculation that was needed in the air rocket lab
    - After figuring out time, use the third kinematics equation to find Vox and Voy
    - In trial one Vox was 5.12 m/s and Voy was 101.4 m/s
    - In trial two Vox was 5.17m/s and Voy was 88.6m/s
    - In trial three Vox was 6 m/s and Voy was 51.3 m/s
    - After finding Vox and Voy you must complete the pythageorean theorem to find the hypotenuse
    - Trials one through three were 101.5 m/s, 88.8 m/s and 51.6 m/s
      • Make it Move Contest
      • Casting Contest
        Casting Contest
      • Woodworking Contest
        Woodworking Contest
      I'm sure my nephews would love this! I'm not sure the house would survive :)
