3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Medieval Trebuchet Out of Cardboard
Of all the Medieval siege engines, the Trebuchet was by far the most accurate and complex. Trebuchets were capable of throwing 350 pound objects over castle walls. While in this Instructable we won't be making a Trebuchet with that much firing power, the design I will show you is capable of throwing a softball 50-60 feet with a 20 lb counterweight.
Video of me shooting the catapult:
(Sorry the video is sideways, I was having technical difficulties)
Step 1Materials
Materials
The Materials that you will need for this project are as follows:
Cardboard! - You will need A LOT of cardboard for this project unless you are lucky like me and find some quadruple-layer cardboard lying around.
Glue - I used Gorilla Glue and suggest that you use the same.
(Optional) Clamps - If you are using Gorilla Glue, you will most likely need clamps to keep your pieces together while the glue cures.
Pipes/Rods - You are going to need pipes for the axles and joints. I used a 3/4 inch acrylic rod for the axles and 3/4 inch PVC pipe for the axle to slide through.
Washers - You will use these to reinforce the joints that will be holding the counterweight and the the "arm" of the catapult. I used washers with a 7/8 inch hole.
Drill+Drill Bits - Depending on the size of your axle, you will need corresponding Drill Bits to make your holes. I used 13/16 inch and 5/8 inch.
Newspaper - Newspaper works really well when you are making your patterns for the cardboard
Rope/Cord - This will be for the "sling" that throws the projectile
Denim/Canvas Fabric - Also for the "sling"
3/16 Inch Steel Rod - This is also for the sling and only needs to be about 6 inches long
You will also need something to cut your cardboard into shape. I used a scroll saw but a knife or other saw might work.
73 comments
1-40 of 73next »
Feb 7, 2011. 11:45 PMyoung skipper says:
Ha, I was randomly looking for things to make on this site and I saw this on the cardboard guide and was like "Is that a cardboard trebuchet?". This is truly amazing.
Apr 9, 2012. 4:53 PMthePhantomoftheOpera says:
That was MY REACTION EXACTLY. With the then-instant addition of "*CLICK*".
Fantastic. My wife is going to just LOVE it when I dive into making THIS. Great!
Feb 15, 2012. 5:14 AMfustigator says:
Very impressive - just though I'd comment because youtube now have an 'edit' feature that lets you rotate your video. Keep up the good work, I watched the huge treblochet at warwick castle hurling a flaming cannonball this weekend which is why my internet wanderings have brought me here!
Nov 10, 2011. 3:24 AMharrydo says:
I mean where do you put the counter weight?
Nov 10, 2011. 3:22 AMharrydo says:
how can you add a weight to it?
Nov 3, 2011. 10:57 AMthatblackguy says:
YOU GUYS ARE ALL SUPER SEXY BTW. ;) ;)
Nov 3, 2011. 11:05 AMthatotherblackguy says:
hey thatblackguy
Nov 3, 2011. 11:04 AMthatotherblackguy says:
i agree with thatblackguy ;) ;)
Oct 16, 2010. 8:30 AMMR.builderguy says:
funny. I have the same scroll saw.
Oct 13, 2010. 12:27 AMtimmy01 says:
neeto!!!!!!!
Sep 29, 2010. 4:11 PMrichhersey says:
What is the biggest challenge you've had with building a Trebuchet?
I'm building a book with tips on building a Trebuchet and would love any tips or advice you have from building a Trebuchet.
Here is the survey form. I did a survey so I can have all the tips gathered from different forums in one place.
Trebuchet Survey
Sep 6, 2010. 5:52 PMTHERCNERD says:
how tall is this trebuchet?
Jul 28, 2009. 2:32 PMknexsuperbuilderfreak says:
can you make a template?
Aug 20, 2010. 2:35 PMhintss says:
kinkos and ask about wide format printing. its expensive, though
Feb 24, 2010. 5:32 AMShelexie says:
This is a great tutorial!  Thanks for the ideas!
Feb 9, 2010. 2:10 PMspark master says:
awesome, awesome awesome
suggestions put some wood in crucial areas for stronger,(longer lasting)  device , you could use old wall paneling for uter most layers or all the layers(you can cut with razor utility knife and do everything EXACTLY as you did here. it would be much stronger.
I think your push pull on the release arm was sheer elegance (simple), and if you do wood make it threaded rod into a nut set in the wood/cardoard arm then you can simply make it longer shorter by turning it.
thanks this was truely magnificent. My kid may want to build one, me too !!!
Sep 28, 2009. 9:00 PMgraysonipper says:
I made one out of wood with similer dimensions but double size I just fired it into a few houses over
Feb 8, 2010. 4:32 AMRiojelon says:
thats a great idea! But don't use heavy wood on part c. use the heaviest avalable wood on the part a. for more power, lenghten part c
Feb 7, 2010. 12:37 PMDudemaster says:
Hi,
can you post measurements in metric as well?
Thanks,
Γι¬ννης
Jul 25, 2009. 10:42 AM112251919112 says:
dude, this is awsome
Feb 7, 2010. 6:43 AMAnalton says:
+1!
Sep 17, 2009. 6:12 PMpyra_builder_1337 says:
neat i may try to make one out of actual wood but this is very innovative
Sep 9, 2009. 2:09 PMTCInc says:
Hey, can you glue two cardboard together to make a bigger one for part B? If you can't, where did you get that big of a cardboard?
Sep 8, 2009. 2:59 PMTCInc says:
Is A2 part of A1? It looks like they fit...
Aug 27, 2009. 5:07 PMthe poodleo says:
i thought this was just a mini one, so im gonna try and make a little desk one like about 10 - 15 cm.. it would be cool if it shot as far as this one in the video.
Aug 6, 2009. 4:57 PMGianniMora says:
how far does this shoot.
Aug 7, 2009. 6:25 PMGianniMora says:
ok cool
Aug 7, 2009. 11:50 AMgeorges bou says:
wonderfull
Aug 5, 2009. 9:46 PMkurth92 says:
im impressed not by the cardboard people who make catapults normally go alright but people who try trebuchet normally fail it all in the sling so tell me the the counter weight completely cardboard ?
Aug 5, 2009. 7:20 PMsoccercheese33 says:
With your first "technically deficient video" what is the final noise in it? contact? Was your quad layer board from a food business? And if you were to take it to a surface not of asphalt or concrete have a cardboard slide/bed that the projectile would slide along to provide minimal resistance in return providing better performance!
Aug 3, 2009. 12:31 AMtotally_screwed says:
I researched trebuchets some years ago and while I was composing a post that might be of use to those interested, I happened-upon the trebuchet page in Wikipedia, which had almost everything I had found!
Since the behaviour of a trebuchet can be unpredictable, a good simulator is recommended. Remeber, the shot may go backwards, forwards or even straight up!
google trebuchet simulator
Aug 3, 2009. 1:01 AMtotally_screwed says:
The last instance of trebuchet use comes from the New World, at the siege of Tenochtitlán (Mexico City) in 1521. As ammunition was running critically low, Cortés eagerly accepted a proposal to build a trebuchet. The machine took several days to build, and at the rst launch the stone went straight up, only to return and smash it.
1-40 of 73next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
130
Author:ineverfinishanyth
I enjoy building and inventing; I have a specific interest in medieval and roman armor and weapons. I am a student in highschool currently and hope to study Mechanical Engineering in college at BYU. I...
more »
