Introduction: How to Make a Mini USB VACUUM CLEANER
Picture of How to Make a Mini USB VACUUM CLEANER
How to make a mini USB VACUUM CLEANER part 1
How to make a mini USB vacuum cleaner part 2
Step 1: To Do a Mini USB Vacuum Cleaner You Need!!!
Picture of To Do a Mini USB Vacuum Cleaner You Need!!!
In today's video I'm going to show you the next idea of crafts and home made things, actually how to make a mini USB vacuum cleaner with your own hands at home!
Step 2: It Is Very Easy to Make a Mini USB Vacuum Cleaner With Your Own Hands, But It Takes a Bit More Time to Construct It!
Picture of It Is Very Easy to Make a Mini USB Vacuum Cleaner With Your Own Hands, But It Takes a Bit More Time to Construct It!
Step 3: With the Help of the Simplest Hand Made USB Vacuum Cleaner You'll Be Able to Remove Some Rubbish From Your Key Board (crumblings, Dust Etc.)
Picture of With the Help of the Simplest Hand Made USB Vacuum Cleaner You'll Be Able to Remove Some Rubbish From Your Key Board (crumblings, Dust Etc.)
Step 4: The Mini USB Vacuum Cleaner Can Help You After You Have Painted or Drawn the Sketch for Removing the Eraser Bits.
Picture of The Mini USB Vacuum Cleaner Can Help You After You Have Painted or Drawn the Sketch for Removing the Eraser Bits.
Step 5: Step by Step!
Picture of Step by Step!
Step 6:
Picture of
Step 7:
Picture of
Step 8: All Parts of the Miniature Hand Made USB Vacuum Cleaner You May Construct From the Make-shifts at Home!
Picture of All Parts of the Miniature Hand Made USB Vacuum Cleaner You May Construct From the Make-shifts at Home!
Step 9: The Construction of the Miniature Hand Made USB Vacuum Cleaner Has a Little Deference From the Real Vacuum Cleaner, As the Air Is Sucked Through the Turbine As Well!
Picture of The Construction of the Miniature Hand Made USB Vacuum Cleaner Has a Little Deference From the Real Vacuum Cleaner, As the Air Is Sucked Through the Turbine As Well!
Step 10: Good Luck in the Creativity and Watch With Pleasure!
Picture of Good Luck in the Creativity and Watch With Pleasure!
revanth001 (author)2016-02-27
where we goin to cut the sheet of tin can u plz give a solution
totemgoat (author)revanth0012016-03-15
tuna can? you'd have to flatten it in a vise or something if it has surface bumps though
loboat (author)2016-02-27
Can I ask you a question romanursuhack ?
loboat (author)loboat2016-02-28
Why did you use a picture of my 3D printed USB Vacuum Cleaner as a fake cover for your video ?
ThomasK19 (author)loboat2016-02-28
You should report that. I don't like people that take without asking.
loboat (author)ThomasK192016-02-29
I already reported his video on YouTube. Except that, that's all I can do...
Akin Yildiz (author)2016-02-27
wow this is very creative
About This Instructable
9,591views
197favorites
License:
Bio: https://www.youtube.com/dashboard?o=U
More by romanursuhack:How to Make a Candle in 30 SecondsHow to Make a Mini CANNON With a Screw-bolt / TutorialMega CRAZY Experiment With a Watermelon
Add instructable to:
