How to Make a Naked Egg for Easter
Introduction: How to Make a Naked Egg for Easter
Egg Contest
Runner Up in the
Egg Contest
A “naked egg” is an egg that has no shell. Let me say that again, an egg with no shell. This is not something you normally run across and even when I show a naked egg to someone they often just don’t get the idea that the shell is gone – yet the egg stays intact.
Step 1: Here’s What You Need
Let’s get to the fun stuff. In order to make a Naked Egg you will need the following items:
1.Vinegar ~16oz/ 473mL( Distilled Vinegar/ White Vinegar or any other type).
2.A couple of glasses or cups.
3.Raw eggs.
4. Corn Syrup
5. Food Colour
6. Time= 12-24Hrs.
In this Instructable I have used both Distilled Vinegar and Sugar Cane Vinegar
Step 2: The Process
IMAGE: An egg soaking in vinegar with part of it’s shell dissolved.
The process is really very simple. Carefully place the egg in a cup and fill the cup with vinegar so that the egg is completely covered. Don’t worry if the egg floats a bit. Just get enough vinegar in the cup to mostly cover the egg.
Now the hard part – you will have to wait as the acetic acid in the vinegar begins to react with the calcium in the egg shell. In just a short while, you should see some bubbles appearing on the outside of the egg. These are bubbles of carbon dioxide gas from the reaction. It can take 12-24 hours before a good portion of the shell is removed. A good sign of progress is a white frothy scummy layer on the top of the surface of the vinegar.
After a day of soaking you can carefully remove the egg from the vinegar. I would suggest pouring the liquid into another cup and catching the egg in your hand. Using a spoon to fish the egg out might seem like a good idea, but I’ve seen a few eggs break or get damaged when using a spoon to remove them.
At this point you may be able to literally rub the shell off the egg with your fingers. It will rub off as a white powdery substance. Give it try, just be very careful, you don’t want to break the egg, it’s getting more fragile as the shell is slowly dissolved. Depending on your particular egg, you may already have a naked egg. However, I would suggest you fill a cup with fresh vinegar and soak the egg for at least one more day.
After two days of soaking you should have a pretty cool Naked Egg. Notice that the egg is a bit bigger than when you first started. This is because some of the vinegar (and some of the  water in the vinegar) has moved through the membranes to the inside of the egg. The membranes are semi-permeable and allow water to move through them. This is called osmosis.
Step 3: How Does It Work?
IMAGE: Chemical Reaction
The shell of an egg (typically a chicken egg) is made up of primarily calcium carbonate. If you soak this egg shell in vinegar (which is about 4% acetic acid), you start a chemical reaction that dissolves the calcium carbonate shell. The acetic acid reacts with the calcium carbonate in the egg shell and releases carbon dioxide gas that you see as bubbles on the shell.
The egg insides remain intact and are held together by the two fragile membranes just inside the shell.
Step 4: Fun Things to Do With Your Naked Eggs
IMAGE: A dehydrated naked egg side-by-side with a brilliant red naked egg soaked in red food colouring.
Naked eggs are cool, but experimenting with them is even cooler. You have probably already noticed that your naked egg is kind of rubbery. How far above the table can you drop your egg and have it survive by bouncing? I would suggest you start at one inch, then try two inches, and so on. Keep in mind that eventually this is going to get messy when it the membrane breaks. You might want to do this experiment outside.
If you want to see your egg get really big, simply put it in a cup filled with water. The makeup of the inside of the egg is around 90% water. If you put the egg in a cup of (100%) water, the water will begin to move inside the egg through the membrane to equalize the amount of water inside and outside of the egg membrane. This process of water moving through a membrane is called osmosis. Osmosis equalizes – or makes the concentration of water on both sides of the egg membrane the same. This means the egg will swell as the water moves inside and get larger.
You can even color the inside of your egg if you soak it in some water with food coloring. This is a nice way to verify that the water in the cup is really moving through the egg membrane and not just coloring the outside.
Step 5: Shrink Your Egg
IMAGE: A naked egg that was soaked in corn syrup for a few days. Much of the water inside the egg has moved out through the membrane.
Now that you know about osmosis, you might ask “can I make my egg shrink” or shrivel up? Of course, you just need a liquid that has only a little bit of water. A common substance you may have at home that fits this requirement is corn syrup.
Slip your Naked Egg into a cup filled with corn syrup and let it sit for a day, or two, or more and you will begin to see your egg begin to shrink and look sort of  baggy. Corn syrup has very little water content. Once inside the syrup, the water inside the egg begins to move across the semi-permeable egg membrane to equalize the water concentration. Again, that’s osmosis at work. If you leave your egg in the syrup long enough it will begin to look something like a huge raisin – with of course a yoke inside.
If you get tired of the shriveled egg look, you can reverse the process by just dunking the egg back in a cup of water. The water will once again move across the membrane and fill the egg with water again.
Step 6: Colour the Naked Egg
IMAGE: A Red Coloured Naked Egg
You can Colour your Naked Egg by adding food colour to some water and soaking the Naked Egg in it
Step 7: Can I Eat the Naked Egg?
“Can I eat my naked egg?” I would NOT recommend eating a naked egg prepared this way. Keep in mind you created your egg by soaking a raw egg in vinegar sitting at room temperature for a few days. That is not how to treat eggs you are going to eat! Even if you stored the egg in the refrigerator, I still would not recommend eating the raw egg. Some have asked if you could store the egg in the fridge, then cook it and eat it. Well, I suppose you could, but given the amount of vinegar that probably moved past the membrane into the egg, it’s most likely not going to taste all that great. Instead of eating your naked egg, just experiment with it.
Step 8: Does It Smell?
It depends on how you store the egg. That rotten egg odor comes from hydrogen sulfide. Eggs contains sulfur because it is needed for the production of feathers in the chicken.
I have not noticed any bad odours with my naked eggs. After dissolving the shell in the vinegar, I keep the egg in a glass of water for up to a week and have not noticed any odor when the egg does accidentally break. It would be an interesting (and probably stinky) experiment to leave an egg out for a week or two in order to give it a chance to start to decompose. I would suspect that as the contents start to decompose, sulfide compounds will begin to form and it will start to smell really bad.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    I have soaked eggs and chicken bones in vinegar when my children were in school and with my girl scout troop. They were fascinated that I had an unboken egg in a bottle and could not figure out how I did it. I had soaked and eggs and then got it in the bottle while it was soft. I let it dry out and it hardened back up. They could not get the egg back out whole. Chicken bones soaked in vinegar could be tied in knots and then were let harden again. Lots of things could be made with vinegar...even lotions. Best use I have for it is pickling and cleaning.
    My brother did that for science class one year. I think it's a really cool idea
    i was surprised and found this to be very interesting. my question. would there be any difference with the chemical reaction if you did hard boil then chemically remove the shell. but then. why would one bother its no longer a naked egg. what an egg head!
    Ive eaten plenty of pickled eggs. Vinegar soaked boiled eggs havent killed me yet. Some might argue otherwise due to the smell after tho.
    i think the key word in your statement was boiled. but if your game, all the power to you!
    Sometimes hens lay them this way if they have a deficiency. Usually they burst in the nest. Time to put out more oyster shells--I think they mix it into their feed now.
