How to Make a Night Vision Camera
2,697
43
5
Posted in TechnologyPhotography
Introduction: How to Make a Night Vision Camera
About: My profile is about making most use out of something and optimum utilization of resources available,dedicated to D.I.Y (Do it yourself) Projects.Easy Hacks,DIY Experiments, Myth Busters & More
Hi Everyone,
In this video Im going to make a Night vision camera using an old Digital camera.
At first let me explain what is a night vision camera.
So im going to make a a day & night Camera
A day and night camera is a security camera that can see the picture during the day hours, when there is enough sunlight, and during the night in total darkness or minimum illumination. A day and night camera has special lenses that allow infrared emission produced by infrared LEDs and reflected from objects to go through and reach a CCD or CMOS chip inside the camera. As a result, the end user can see picture in total darkness at the distance of infrared emission produced by LEDs. A day and night camera can have infrared LEDs mounted on its housing or can accept the emission, produced by an infrared turret. Day and night cameras often have modifications in their digital signal processor (DSP) that compensates for the difference in illumination between day and night modes. HDR technology may also be used in more expensive models to compensate for the difference in illumination between shaded and lighted areas of surveillance.
Step 1: Parts
In this project i Used an old canon ixus 130 point & shoot camera which was given by my friend as no longer needed it.
Philips screw driver as per the size of the screw of you digital camera
Hot glue gun
Soldering iron
Toggle switch
IR leds or IR led ring of a CCTV camera
Some wires
Tweezers Or forceps
Step 2: Opening the Camera
Carefully open the Outer casing of the camera with a precision screw driver
Step 3: Remove the LCD Panel
After the casing is removed you need to remove the LCD panel which is attached to a ribbon cable
depending upon the make model the placement might be different however you can always find that on World Wide Web in my camera it was on the front
the ribbon cable is secured with small clip slide the clip on top and cable will come out check the images for reference.
Step 4: Open the Camera Sensor
Once you remove the LCD panel you will see the camera sensor.
BE EXTREMELY CAREFUL WHILE DO THIS ANY DAMAGE TO THE SENSOR & THE CAMERA IS OF NO USE THEN
"IF YOU'RE A MINOR THEN PLEASE DO THIS UNDER ADULT SUPERVISION"
The Sensor i secured with four screws and on each screw there is some glue which can be removed of easily
once you remove the screws you will have to open the sensor.
The colorful glass what you see is the sensor( check the image for reference).
Step 5: Remove the IR FIlter
Film is usually sensitive to visible light too, so an infrared-passing filter is used; this lets infrared (IR) light pass through to the camera, but blocks all or most of the visible light spectrum (the filter thus looks black or deep red).
If we remove the IR filter the camera would be able to see Infrared Spectrum of Light.
So this Small filament what you see is on top of the Camera sensor or on the opening of the shutter
Carefully remove it and keep it aside.
Now place the sensor back and secure it with Screws
Step 6: Place Everything Back in Place
Once the IR Pass Filter is removed
Secure the sensor back with the screws,
Place the LCD panel back and connect the ribbon cable back
Before putting the outer casing insert the battery and switch on the camera and check it should work
Once its working do a test take your TV remote and press any buttons on the TV remote and you should be able to see the IR led Blinking.
Step 7: Making a IR Led Connection
SO now the IR FIlter is removed we can make a IR Torch for this camera so that we can see in the dark.
I had a IR led ring from an old CCTV camera which worked well
It works on 12 volts
so I connected it to a 12 volt adapter with a Switch
Usually all the IR Rings have a Light detecting sensor which only works when its dark
Step 8: Connecting the Led to Power Source
Connect Simple wiring with a Switch and use a DC female pin as a power connecter for the 12 volts.
Solder the wires to the switch and use heat shrink tubing wherever required.
Step 9: Placing the Led
I used some small round acrylic cutouts which were left overs of my previous project this act as a standoff for my
Led ring which I stuck to the camera.
Step 10: Time to Test
Works really well.
The images shown are take in pitch dark with the help of the IR LEDs.
Had fun to playing with it
And I might make a Portable power supply so that it can be carried anywhere.
Thank you
You can also subscribe me on Youtube
https://www.youtube.com/watch?v=seeXLo8g0YU
See you next time
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    5 Comments
    Hi, good instructable - thanks.
    I have noticed some IR leds glow red when on - thereby giving away any covert intentions for the night vision camera - whilst other IR leds do not - could you let me know what the spec difference is and which I should buy for non-glow IR leds??
    Many thanks
    D6
    If you use the Individual Leds Which i used in my IR Blaster project they don't glow red but you need to use many in the series to get a good effect.
    So the one I used for IR camera is different.
    IR LED's don't actually emit light in what is considered the visible spectrum. What happens is the source is in fact VERY BRIGHT in the near IR spectrum. While your eye sensitivity to near IR is very poor, it usually isn't zero. Hence the ability to see a very bright near IR source at close range.
    940 nm is about as good as it will get in surface mount.will not be visible as you will find and is very hard to see. Even while holding in your hand you have to look very close to see if it is working.
    for cheaper option go for the cheap IR leds which i used in the IR blaster they are not visible
    I don't know the specs of the led however you can use any standalone IR leds also you can use the IR leds of the TV or any remote. I used the entire circuit of the CCTV IR LED ring it worked fine
    You can use any IR leds you want, I used the led of a CCTV camera. i have also tried it with the individual leds it works fine
