Introduction: How to Make a Pair of Handmade 2-Hole Seed Bead and Pearl Bead Star Earrings
This Pandahall article is about a pair of handmade 2-hole seed bead and pearl bead star earrings. The following tutorial will show you how to make the star earrings.
Step 1: Supplies Needed in DIY the 2-hole Seed Bead and Pearl Star Earrings:
5x3.5x3mm Green 2-Hole Seed Beads
5x3.5x3mm Orange 2-Hole Seed Beads
6x4mm LightKhaki Drop Glass Beads
3mm White Round Pearl Beads
6mm Clear Bicone Glass Beads
Needles
0.2mm White Fishing Wire
Silver Hoop Earrings
Stainless-Steel Scissor
Step 2: Make the First Part of the 2-hole Seed Bead and Pearl Star Earrings
1st, cut a part of 0.2mm white fishing wire. Then, thread a 3mm white round pearl bead, a 6mm clear bicone glass bead, a 3mm white round pearl bead, a 6mm clear bicone glass bead, a 3mm white round pearl bead and 3 5x3.5x3mm green 2-hole seed beads in sequence to the wire(as shown in the picture);
2nd, combine the beads together into a hoop by crossing the wires through the beads (as shown in the picture);
3rd, thread a 3mm white round pearl bead, a 6mm clear bicone glass bead, a 3mm white round pearl bead, 3 green 2-hole seed beads and a white pearl bead in sequence to the right wire(as shown in the picture);
4th, make a hoop with the beads by crossing the right wire through the 2nd clear bicone glass bead and the white round pearl bead (as shown in the picture);
5th, refer to the above steps to make two more such patterns. Then, thread a white round pearl bead, 3 green 2-hole seed beads and a white pearl bead in sequence to the wire (as shown in the picture);
6th, combine the beads into a flower by crossing the wires through the clear bicone glad beads and white pearl beads (as shown in the picture).
Step 3: Make the Second Part of the 2-hole Seed Bead and Pearl Star Earrings
1st, cross the wire through the other hole of a green 2-hole seed bead. Then, add an orange 2-hole seed bead and cross the wire through the other hole of the adjacent green 2-hole seed bead. Add another orange 2-hole seed bead and cross the wire through the other hole of the third green 2-hole seed bead. Then, add a 6x4mm light khaki drop glass bead (as shown in the picture);
2nd, refer to the above step to add 2 orange 2-hole seed beads;
3rd, refer to the above steps to add more 6x4mm light khaki drop glass beads and orange 2-hole seed beads (as shown in the picture).
Step 4: Make the Third Part of the 2-hole Seed Bead and Pearl Star Earrings
1st, cross the wire through the other hole of the orange 2-hole seed bead. Then, add an orange 2-hole seed bead and cross the wire through the other hole of the adjacent orange 2-hole seed bead. Add a white round pearl bead (as shown in the picture);
2nd, cross the wire through the adjacent light khaki drop glass bead. Then, add a white round pearl bead (as shown in the picture);
3rd, cross the wire through the other hole of the orange 2-hole seed bead. Then, add an orange 2-hole seed bead and cross the wire through the other hole of the adjacent orange 2-hole seed bead. Add a white round pearl bead and cross the wire through the adjacent light khaki drop glass bead (as shown in the picture);
4th, refer to the above steps to make more such patterns (as shown in the picture).
Step 5: Make the Fourth Part of the 2-hole Seed Bead and Pearl Star Earrings
1st, add 3 white pearl beads;
2nd, cross the wire through the other hole of the orange 2-hole seed bead. Then, add 2 white pearl beads (as shown in the picture);
3rd, cross the wire through the white pearl bead, the light khaki drop glass bead and the adjacent white pearl bead in sequence (as shown in the picture);
4th, refer to the above steps to add white pearl beads and cross the wires through the other hole of the orange 2-hole seed beads (as shown in the picture).
Step 6: Make the Rest Part of the 2-hole Seed Bead and Pearl Star Earrings
1st, cross the wire through the 3 white pearl beads. Then, add a white round pearl bead;
2nd, cross the wire through the adjacent 3 white pearl beads, the light khaki drop glass bead and the 3 white pearl beads;
3rd, refer to the above steps to add a white round pearl bead to the other four angles;
4th, add a silver hoop earring;
Step 7:
5th, refer to the above steps to make the other pair of the 2-hole seed bead and pearl bead star earrings.
Here is the final look of the 2-hole seed bead and pearl bead star earrings.
Are you attracted by the handmade 2-hole seed bead and pearl bead star earrings? The beading and stitching techniques are not very complicated. Just have a try if you like the star earrings.
