Step 2Papier Mache It!
Support your head on something round that papier mache will not stick to. An old ceramic mug is a good choice.
Rip short sections off of your newspaper strips as you go and dip them in the liquid. Get them thoroughly wet, but slide your fingers over each strip to wring off excess (you don't want it to drip everywhere). Completely cover your shape with the wet newspaper strips. You can use broader strips for less detailed areas, but to cover those pesky curves and corners thinner strips work better. When finished let it dry a bit (it will dry faster if you point a fan at it).
Repeat about 7 times. You will need about 7 layers to make your puppet strong enough to stand up to use. An easy way to keep track of your layers is to switch back and forth between newspaper layers and paper towel layers (use the paper towels the same way you use the newspaper).
Add Comment
