Step 4Time to Make the Body
Now that you have your pieces cut out, sew them together along both sides (leave the top and bottom open). If sewing is not a possibility for you, you can also glue them together along the edges with tacky glue or hot glue, but make sure that the glue is completely dry before you move on.
Using sharp scissors, cut short slits from the outside almost to the seam near the tightest curves (such as just under the amrs). This is known as "clipping curves" and will keep these areas from bunching when you turn it. Next, turn your body right side out and you are done.
Add Comment
