How to Make a Pencil Drawing Piano
3,368
41
Published
Introduction: How to Make a Pencil Drawing Piano
About: We're an ambitious team for developing STEM education by Arduino and Raspberry Pi learning kits as well as robots and aircraft models/drones. Happy to bring you more fun projects and works. Welcome to visit ...
Piano is an amazing instrument which makes wonderful music. With a Multi-Control board at hand, let’s make our own piano.
Any conductors can be used as keys for the piano. Here we make a pretty pencil drawing piano.
Step 1: Prepare Materials
Multi-Control board - http://bit.ly/2sTJYxx
Mini USB cable
Some alligator clip cables (included in Multi-Control kit)
6B pencil or softer one
Eraser for 6B pencil
Paper
Computer
Step 2: Draw the Musical Notation With Pencil
Draw the musical stave and notation on a blank paper, drew stave with gel pen and seven notes with pencil, and mark them with C, D, E, F, G, A, and B separately.
Note: you must use a pencil or fountain pen to draw to ensure good conductivity lines, or it may fail to work.
You can add more notes if you like.
Step 3: Retrace the Drawing Lines
To ensure good conductivity, retrace the drawing lines especially the alligator clipping parts and the touching parts.
Step 4: Wiring
Connect the Multi-Control to Notes by clipping to the holes and the drawing notes one by one as follows:
Multi-Control Board------------------Notes
C-------------------------------------------C
D-------------------------------------------D
E-------------------------------------------E
F-------------------------------------------F
G------------------------------------------G
A------------------------------------------A
B------------------------------------------B
Then extend the GND of Multi-Control with an alligator clip cable.
Step 5: Upload Code to the Multi-Control
Visit the WiKi page of Multi-Control, you can see the related resources.
Click HERE to download the library. Click Sketch -> Include Library -> Add .ZIP Library, then include the download library, including Joystick and MIDIUSB.
Then go to Github page and download the code.
Unzip the download package. Open multi-control-midi.ino. Then select the board type (Leonardo) and port, and upload the code.
Here is the code:
* Filename : multi-control-midi.ino * Description : SunFounder multi-control midi device driver * Author : Dream * Brand : SunFounder * E-mail : service@sunfounder.com * Website : www.sunfounder.com * Update : V1.0.0 2017-3-15 * * * This code fits SunFounder multi-control product,which is used to simulate midi device functions. * 1.A1,A2 for scale adjustment:A1 conducts, shift to an octave up; A2 conducts, shift to an octave down; * A1 & A2 all conduct, shift to an transpose up. * 2.A3-A10 for tones:corresponds to tone C5, D5, E5, F5, G5, A5, B5, C6(in piano keyboard mode). * 3.Piano and drum supporting,comment out #define KEYBOARD,and uncomment //#define DRUM to shift to DRUM mode. * * easy-to-do DIY: * DEBUG When it is 1, it will print the debugging information. * MINTOUCH 900 sensitivity of holes(0-1023), the larger the parameter is, the more sensitive they will be. * In header file notemap.h, you can modify the holes' midi tones and velocity parameter mapping. **********************************************************************/ #define KEYBOARD // uncomment to shift to piano keboard mode //#define DRUM // uncomment to shift to drum mode #include "MIDIUSB.h" #include "notemap.h"
#define DEBUG 0 // When it is 1, it will print the debugging information #define MINTOUCH 900 // sensitivity of holes(0-1023), the larger the parameter is, the more sensitive they will be
int mod = 0; // for scale adjustment, Octave parameter
const int Mode = 7; // Switch, to turn on/off the touching holes const int channelPlus = 3; // button A, used to configure channel function const int channelMinus = 2; // button B, used to configure channel function int statusMode = 0; //============================================== // Set variables // holeAX[0] the analog value to be read valueAX // holeAX[1] analog to digital one statusAX // holeAX[2] output the value only when it changes lastStatusAX // holeAX[3] note map NOTE_AX // holeAX[4] lastNoteAX, value of modified tone lastNoteAX int holeA1[] = {0, 0, 0, 0}; int holeA2[] = {0, 0, 0, 0}; int holeC[] = {0, 0, 0, NOTE_C, 0}; int holeD[] = {0, 0, 0, NOTE_D, 0}; int holeE[] = {0, 0, 0, NOTE_E, 0}; int holeF[] = {0, 0, 0, NOTE_F, 0}; int holeG[] = {0, 0, 0, NOTE_G, 0}; int holeA[] = {0, 0, 0, NOTE_A, 0}; int holeB[] = {0, 0, 0, NOTE_B, 0}; int holeCP[] = {0, 0, 0, NOTE_CP, 0};
void setup() { Serial.begin(115200); pinMode(channelPlus, INPUT_PULLUP); pinMode(channelMinus, INPUT_PULLUP); controlChange(channel, CONTROL_VOLUME, 127); // setup channel }
void readStatus(){ // read the analog, and shift to digital one to store in array holeX[1] statusMode = digitalRead(Mode); //if(statusMode == 0){ // hole switch holeA1[0] = analogRead(A1); holeA2[0] = analogRead(A2); holeC[0] = analogRead(A3); holeD[0] = analogRead(A4); holeE[0] = analogRead(A5); holeF[0] = analogRead(A6); holeG[0] = analogRead(A7); holeA[0] = analogRead(A8); holeB[0] = analogRead(A9); holeCP[0] = analogRead(A10);
if (holeA1[0] < MINTOUCH) holeA1[1] = 0; else holeA1[1] = 1; if (holeA2[0] < MINTOUCH) holeA2[1] = 0; else holeA2[1] = 1; if (holeC[0] < MINTOUCH) holeC[1] = 0; else holeC[1] = 1; if (holeD[0] < MINTOUCH) holeD[1] = 0; else holeD[1] = 1; if (holeE[0] < MINTOUCH) holeE[1] = 0; else holeE[1] = 1; if (holeF[0] < MINTOUCH) holeF[1] = 0; else holeF[1] = 1; if (holeG[0] < MINTOUCH) holeG[1] = 0; else holeG[1] = 1; if (holeA[0] < MINTOUCH) holeA[1] = 0; else holeA[1] = 1; if (holeB[0] < MINTOUCH) holeB[1] = 0; else holeB[1] = 1; if (holeCP[0] < MINTOUCH) holeCP[1] = 0; else holeCP[1] = 1; //} if(DEBUG){printValue();} }
void printValue(){ // Serial Plotter Serial.print(holeA1[0]);Serial.print(','); Serial.print(holeA2[0]);Serial.print(','); Serial.print(holeC[0]);Serial.print(','); Serial.print(holeD[0]);Serial.print(','); Serial.print(holeE[0]);Serial.print(','); Serial.print(holeF[0]);Serial.print(','); Serial.print(holeG[0]);Serial.print(','); Serial.print(holeA[0]);Serial.print(','); Serial.print(holeB[0]);Serial.print(','); Serial.print(holeCP[0]);Serial.print(','); Serial.print(0);Serial.print(','); Serial.print(MINTOUCH);Serial.print(','); Serial.println(1023); }
void holeHandle(int *holeAX){ // handle for hole function if(holeAX[2] != holeAX[1]){ // Status change if(holeAX[1] == 0){ // one hole conducts, produce corresponding sound noteOn(channel, (holeAX[3] + mod), currentVelocity); holeAX[4] = holeAX[3] + mod; Serial.print("noteOn ");Serial.println(holeAX[3] + mod); } else{ // hole conducts, no sound is produced noteOff(channel, holeAX[4], currentVelocity); Serial.print(" noteOff ");Serial.println(holeAX[4]); } holeAX[2] = holeAX[1]; } //delay(20); }
int channelDebug(){// configure channel // press A once, add 1 to channel value, press B once, take 1 from channel value // after configuration, we know keyboard channel is 0, drum channel is 9. int a = digitalRead(channelPlus); int b = digitalRead(channelMinus); int channel = 0; if(a == 0){ // add to channel while(a == 0){a = digitalRead(channelPlus);} if(a == 1){ channel += 1; if(channel > 15){channel = 15;} } }
if(b == 0){ // take from channel while(b == 0){b = digitalRead(channelMinus);} if(b == 1){ channel -= 1; if(channel < 0){channel = 0;} } } return channel; }
int controlOctave(){// A1,A2 is control scale adjustment if((holeA1[1] + holeA2[1]) == 0) // A1 and A2 conduct, shift to an transpose up mod = 1; else if (holeA1[1] == 0) // A1 conducts, shift to an octave up mod = 12; else if (holeA2[1] == 0) // A2 conducts, shift to an octave down mod = -12; else mod = 0; return mod; }
void scan(){ // scan all the buttons status /*// configure channel channelDebug(); */ // A1 A2 mod = controlOctave(); // C holeHandle(holeC); // D holeHandle(holeD); // E holeHandle(holeE); // F holeHandle(holeF); // G holeHandle(holeG); // A holeHandle(holeA); // B holeHandle(holeB); // CP holeHandle(holeCP); }
void loop() { readStatus(); scan(); }
// First parameter is the event type (0x09 = note on, 0x08 = note off). // Second parameter is note-on/note-off, combined with the channel. // Channel can be anything between 0-15. Typically reported to the user as 1-16. // Third parameter is the note number (48 = middle C). // Fourth parameter is the velocity (64 = normal, 127 = fastest). void noteOn(byte chn, byte pitch, byte velocity) { midiEventPacket_t noteOn = {0x09, 0x90 | chn, pitch, velocity}; MidiUSB.sendMIDI(noteOn); MidiUSB.flush(); } void noteOff(byte chn, byte pitch, byte velocity) { midiEventPacket_t noteOff = {0x08, 0x80 | chn, pitch, velocity}; MidiUSB.sendMIDI(noteOff); MidiUSB.flush(); }
// First parameter is the event type (0x0B = control change). // Second parameter is the event type, combined with the channel. // Third parameter is the control number number (0-119). // Fourth parameter is the control value (0-127). void controlChange(byte chn, byte ctrl, byte value) { midiEventPacket_t event = {0x0B, 0xB0 | chn, ctrl, value}; MidiUSB.sendMIDI(event); MidiUSB.flush(); }
Step 6: Adjust Touch Sensitivity
Open a MIDI software and complete the initial setting. Then hold the GND and touch a note, if a pressed key is shown on the MIDI, it means this note conducts. Since conductivity varies among different objects, which may affect the touch sensitivity, so set a proper value of touch sensitivity for the pencil drawing. The bigger MINTOUCH value set, the more sensitive it will be.
Step 7: Enjoy Your Hand-drawing Piano!
Now, you get a DIY touch piano! Time to play piano! Have fun!
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    3 Discussions
    Nice. Do you have some other projects for this board?
    The only thing missing in your instructable is which MIDI software to use. It would be nice to have some info on free programs, in which this can be used.
