How to Make a Pickle Harpoon
12,955
18
25
Posted
Introduction: How to Make a Pickle Harpoon
I got the idea from the halfbakery and i decided to "bake" it
http://www.halfbakery.com/idea/Pickle_20Harpoon
Step 1: Gather Supplies
For this Project you will need these things;
Small Spring Cannon (my other instructable)
duct tape
jigsaw blade
small thread spool
1/2 in wooden dowel
nail
2 washers
hot glue
scrap wood
tools;
saw
metal grinder
vice (or pliers)
hot glue gun
drill
Step 2: Make the Harpoon Gun
cut a piece of scrap wood about 2 in by 8 in by 1/2 in
drill a hole in the upper corner right or left (slightly smaller than the nail)
sandwich the thread spool between two washers and stick the nail through
hammer the nail into the hole so the spool can't move side to side, but can rotate freely
duct tape the spring cannon to the wood
Step 3: Make the Harpoon P1
cut the dowel to about 2 1/2 in
cut a notch at the diameter
drill a hole in the middle
thread the string through and tie it
Step 4: Make the Harpoon P2
use the vice to break the jigsaw blade in half
(clamp it and bend it until it breaks)
use the grinder to sharpen the tips
put hot glue on the notched end of the dowel
stick the blades in the notch throught the molten hot glue (teeth pointing out)
let the glue cool
Step 5: Finish It
make sure the harpoon fits in the cannon
if it slides out when pointed down use pliers to bend the barrel slightly
the harpoon should easily come out but not easy enough for it to fall out
the harpoon blade looks awesome
Step 6: Go Pickle Hunting
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    25 Comments
    the gravity where you are is F-'d up
    that or i don't have the sense to tilt my head (_)
    nice work on the harpwn
    What if the gravity where he is isnt F-'d up but instead our gravity is F-'d up ʎʞɐǝɹɟ
    ya and fun till theres one pickle left
    Just a suggestion that may be helpful. Try winding your recovery line (thread/string) on parallel 2 rods that are oriented towards the target (pickle). Wind the line starting closest to the base and working toward the tip. This will cause less drag on the projectile and thus, you will achieve greater range.
    this is possibly the worst thing I have ever seen in my entire life. why would you even bother posting this piece of crap on the Internet. Just Kidding its actually really good. i made one today. it doesn't work. just kidding it actually does work.
    hey this is a relly good instructable bt the blade is from a hack saw not a jig saw but still relly good
