How to Make a Pink and Clear Glass Bead Flower Bracelet for Girls
2,595
91
4
Published
Introduction: How to Make a Pink and Clear Glass Bead Flower Bracelet for Girls
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
In this Pandahall tutorial, you can see a pink and clear glass bead flower bracelet. Follow me to see how to make this glass bead flower bracelet.
Step 1: Supplies Needed in DIY the Pink and Clear Glass Bead Bracelet:
6mm Clear Bicone Glass Beads
6mm Pink Bicone Glass Beads
6mm Green Bicone Glass Beads
Silver Ring End Clasps
Silver Headpins
Silver Jump Rings
Platinum Bead Tips
0.3mm Tiger Tail
Stainless-Steel Scissor
Needle Nose Plier
Step 2: Make the First Part of the Pink Glass Bead Flower Bracelet
1st, cut a part of 0.3mm tiger tail and thread 5 6mm pink bicone glass beads;
2nd, thread another pink glass bead to the right tiger tail and cross the tiger tail through the two right pink glass beads. Then, cross the left tiger tail through the upper pink glass bead in the middle and the two left pink glass beads (as shown in the 1st picture below);
3rd, cross the two tiger tails through another pink glass bead;
4th, thread 2 6mm clear bicone glass beads to the right tiger tail. Then, thread a 6mm green bicone glass bead and a 6mm clear bicone glass bead to the left tiger tail. Cross the two tiger tails through another clear glass bead (as shown in the 3rd picture below);
5th, thread 2 clear glass beads to the right tiger tail. Thread a green glass bead and a pink glass bead to the left tiger tail. Then, cross the two tiger tails through a green glass bead (as shown in the 4th picture below);
6th, thread 2 clear glass beads to the right tiger tail. Thread a pink glass bead and a green glass bead to the left tiger tail. Then, cross the two tiger tails through a clear glass bead (as shown in the 4th picture below).
Step 3: Make the Second Part of the Pink Glass Bead Flower Bracelet
1st, thread 2 clear glass beads to the right tiger tail. Thread a clear glass bead and a green glass bead to the left tiger tail. Then, cross the two tiger tails through a pink glass bead (as shown in the 1st picture below);
2nd, refer to the 1st step in Step 1 to make a pink flower pattern (as shown in the 1st picture below);
3rd, refer to the 4th step and the 5th step to make two flower patterns (as shown in the 2nd picture below);
4th, thread a clear, green and pink glass beads to the right tiger tail in sequence. Then, cross the same tiger tail through the green, clear, green and pink glass beads to make a loop(as shown in the 2nd picture below);
5th, cross the tiger tail through the adjacent pink glass bead. Thread a pink glass bead and cross the tiger tail through the two pink glass beads of the hoop. Thread 3 pink glass beads to the other tiger tail. Then, cross the tiger tail through the middle pink glass bead and the two pink glass beads (as shown in the 3rd picture below);
6th, thread 2 clear glass beads to the right tiger tail. Thread a green glass bead to the let tiger tail and cross the tiger tail through the adjacent clear glass bead. Then, cross the two tiger tails through another clear glass bead. Refer to the above steps to make more bead flower patterns (as shown in the 4th picture below).
Step 4: Make the Rest Part of the Pink Glass Bead Flower Bracelet
1st, thread a clear glass bead to the tiger tail;
2nd, add a bead tip and some silver jump rings. Combine a green glass bead with a silver headpin. Then, add it to the jump ring (as shown in the picture);
3rd, add a bead tip to the other tiger tail. Then, connect the two ends of the pink and clear glass bead flower bracelet together through a silver ring end clasp.
Step 5: Here Is the Final Look of the Pink and Clear Glass Bead Flower Bracelet.
Do you love this pink and clear glass bead flower bracelet? As you can see from the above tutorial, the bead flower patterns are quite simple. So, just collect some glass beads and have a nice try!
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    4 Comments
    Yes, I will show you simpler flower bracelet, please pay attention! Thanks!!
