3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Portable Game System
Step 14Relocating the Cartridge Connector
What You Need:
Soldering Iron
Lots of wire
Wire stripper
72 pin connector (link in previous step)
Plenty of patience
If you want to put the cartridge connector somewhere other that at the top of the NES board, you need to do what is called "relocating" it. This is where you extend the slot by soldering wires to all the connections on the NES and to the cartridge slot.
You need 72 wires (IDE cable works great for relocations) for this. Strip both ends of all the wires and tin them. Tin the contacts on the NES board and on the connector.
Then, start soldering the wires to the NES and to the connector. Simply make sure you correspond the right contacts. Just look at the soldered connector in the previous step and pretend to pull it away from the board. Make sure you double check your wires when you're don't and make sure they're no longer that 6 inches.
1 comment
Aug 2, 2011. 9:24 PMNisalotaco says:
would there be a way to pull the cartridge connector into the body of the handheld so that the thing doesnt look like it might fall off?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
266
Author:1up(ModRetro)
Sometimes my Instructables are few and far between, but I try to make them as well as I can. Hopefully you can be inspired or helped by the content in them!
