3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Portable Game System
Step 17Build the Power Regulator
What you need:
Soldering Iron
Medium-sized piece of perfboard
7805 Regulator (From the RF box)
Heatsink (You can use the one from the RF box if you like)
1,000uf Capacitor
Two 0.1uf Capacitors
1 - 10uf Capacitor
1N4001 Diode
Before we start, you have to understand what a regulator is and what it does. A regulator takes any voltage above a certain amount and drops it to a specified voltage. For example, the 7805 regulator we are using takes anything from 7.5 - 36 volts and drops it to 5v, which is what we need for the NES. The extra energy is given off as heat, so you need something called a heatsink. A heatsink attaches to the regulator and dissipates the heat coming from it. Without a heatsink, the regulator would burn itself out. The more surface area a heatsink has, the better it takes heat away from the regulator. You can use the one from the RF box.
Note: A 7805 needs at least 7.5v to run, so you must make sure your batteries are at least that much.
SOLDERING THE BOARD
Anyways, the schematic for the regulator is in the first picture. It has a drawing of the regulator and its pins. Pin 1 is the voltage in, pin 3 is ground, and pin 2 is five volts out.
The reason for all the capacitors is to smooth out any ripples in the voltage coming from the batteries. C1 can be anything from 250uf to 1,000uf, and smooths the voltage coming straight from the battery. I just used what I had lying around, which was a 250uf cap. C2, C3, and C4 smooth out the current coming from the regulator.
Some capacitors can probably be excluded, like C1 (1,000uF) and C4 (.1uF). Also, C1 could be around 470uF as well. The values aren't all that critical.
OPTIONAL
The diode, D1, is not necessary. It is only there to drop the voltage by about 1v, because I found that the regulator really gave out 6v. The NES will be fine running at 6v, but I just wanted to be safe.
I used a 3-pin connector for my regulator board, because I wanted it to be removable.You don't have to, but it does make things easier.
See above note about capacitors.
TESTING THE BOARD
You can finally test your NES! Solder the output pin on your regulator (+5v out) to the 5v in on the NES, and attach ground. Use a couple of alligator clips to hook it up to a TV. Plug in a cartridge (Make sure it's facing the right way!), add the battery, and try it out! If it doesn't work, don't worry. Try switching the alligator clips for video and ground. If it still doesn't work, check all your connections. Make sure there are no shorts anywhere. It is highly unlikely you fried your NES. Once you get it working, set it aside and get out the screen you ordered.
62 comments
1-40 of 62next »
Dec 21, 2011. 11:09 AMAza1234 says:
Would I still need a power regulator if I used 4 1.5V AA batteries
May 19, 2011. 5:45 AMsasrani says:
Can you please give some more information I'm very bad at this thing :(
Jul 25, 2011. 3:15 PM64bitgenius says:
not to disappoint you, but if your bad at these things then you should probably not try this first as you will end up wasting a good amount of time and money because of screw ups; I suggest you try to do simpler things to sharpen up your skills, but don't take my words too seriously because this would be a great opportunity to gain experience.
May 19, 2011. 11:08 AMDreaded Boss says:
Exactly what do you need help with? We can go step by step.
Jul 24, 2011. 6:12 AMgravythis28 says:
In the second picture it looks as though the battery leads to both the input and ground pins?
Jul 20, 2011. 3:47 PMcrybaby810 says:
Your explanations are great! I'm just glad your still answering questions, I saw that this article was posted three years ago so I was a little worried I wouldn't get a response. I just got my screen in the mail today so its not long before I crank this sucker out.
I do have one last question before I start actually soldering the regulator though. I see that your regulator has what look like polyester film capacitors, I'm assuming those are the two 0.1 uF capacitors from the diagram, but they are not polarized, correct? I ask because I have two 0.1uF capacitors that are polyester film and look exactly like the ones in your picture and I was curious if they would work for the regulator even though they don't seem to be polarized?
Jul 19, 2011. 3:40 PMcrybaby810 says:
One more question good sir:
So I get that you have pin 2 leading to your NES, but does that mean that you have the battery running directly to pin 1 and then have pin 3 (the ground) lead to your screen, or do you wire the battery to your screen first and then have a wire from your screen to pin 1 (and then ground the wire from pin 3 to the mother board like the video amp)? I ask because if you have two output wires leading from the battery, (one to the screen and one to the NES) then wouldn't the current would choose whichever path was shorter ( this is according to my third grade knowledge of circuitry)?
Jul 15, 2011. 5:12 AMcrybaby810 says:
So after tooling around on google, I realized that the diagram does not show an actual connection between the ground wire and the capacitors, at least that is what I take from the pictures. So then can someone explain to me why there are those little crow feet extending from the ground wire towards the capacitors in the drawing of the circuit? I assume it is supposed to represent something about the flow of current within the circuit?
Also, the diagram shows the ground wire leaving in two directions, so I assume that answers my previous question about powering the screen, as one wire is grounded to the NES board and the other would lead back to the screen and battery, correct?
Jul 15, 2011. 5:30 AMcrybaby810 says:
What I mean to say about the capacitors is that in the drawing there is not anything actually connecting the empty space between the T's extending from the ground (wire 3) and from wires 1 and 2, so I can infer that the capacitors should only be connected to wires 1 and 2, and the T's (with the curved tops) coming from the ground wire (wire 3) in the diagram are simply some just some sort of formal way to articulate the flow of current for those engineers reading ?
May 19, 2011. 11:28 AMDreaded Boss says:
Actually, all you could use is the regulator and screw it to the metal part of the NES board. The metal would act as a heat sink. Cheaper and easier. Not to mention the space you'll save in your portable. Here is where I put mine:
Feb 15, 2011. 8:52 PMT_T_ says:
quick question, could I charge this battery like a normal battery?
I'm not sure if it has the charging circuit built in.
Mar 4, 2011. 7:32 AMbuckminsterfullerene says:
No, you will need an external charging system, one specifically designed for li-polymer batteries. If you dont use one specifically designed for that use, nasty things can happen as you may know if you have seen kipkays video
Nov 16, 2010. 12:37 PMredsoup says:
or you could buy one
Sep 24, 2010. 12:46 PMhunter566 says:
This is i little off topic but can u tell me how to make a 8.5 volt power regulator this is for a playstation 2 slim
Sep 28, 2010. 6:38 AMhtetkyawlwin says:
you could use 7808 regulator IC to make nearly 8.6 volts output but it could not use more than 1.5 amperes.
Oct 25, 2010. 3:02 PMkillersquirel11 says:
That can't possibly source enough current to run a PS2. Your only option would be a switching regulator (assuming you are running off of battery. Wall power could be regulated using a wall wart).
I would recommend building your own (if you can). National Semiconductor (www.national.com) has a good calculator which allows you to pick your specs (?V in, 8.5V out, 5.3A - might want to call it 5.5 or 6A) and then designs the schematic etc for you. That's how you'd make one yourself.
A quick search (of digikey) yielded no reasonably-priced results for pre-built supplies.
If you want to continue searching, keywords:  DC-DC converter, Switching Regulator
Aug 24, 2010. 4:47 AMapenjong-31295 says:
you said "A 7805 needs at least 7.5v to run.", but my li-ion battery is 7.4v. does that mean i can still use a 7805, or do i need a regulator with a lower spec?
Aug 20, 2010. 5:38 AMredsoup says:
can a Nes run on 6.5v
Aug 20, 2010. 8:57 PMredsoup says:
well 9v battery + the regulator in diagram equals 6.5v i could add another d1 but the portable would be fat, safty first... i think
Aug 21, 2010. 6:07 AMredsoup says:
just to be safe and not get screwed i can run them on this NimH battery pack i have though feeding a 12v screen 6v will work, but i did get a screen built for gaming so i could fix it
Aug 14, 2010. 7:36 AMnickmaynard says:
so, this regulator puts out 5 volts. but how do you power the screen off of that when the screen needs 7.5?
Aug 12, 2010. 2:57 PMmarioluigi1 says:
Hello again. I bought another NES and started again cause I couldn't get anything working at all! It all worked fine until I got to this part again. The first time I tested it though I did accidentally swap pins 2 and 3 over on the regulator, could this have killed my NES? I even connected an LED (with a resistor) to the NES and it doesn't light up! Please help... again :) Also... is ground just connected to the big, flat metal bit in the corner and +5V just connected to the 5V (middle) pin on the nes? Cause that's what I did! :) Thanks!
Aug 13, 2010. 3:13 AMmarioluigi1 says:
OK. :( But I thought that if the LED didn't come on, I was ok because it meant no power was even getting to the NES? lol... i am confused! Also, if I have fried my NES, is there any way I can fix it without buying a 3rd one? Thanks again.
Aug 8, 2010. 9:54 PMTheLHP says:
Hey i got the regulator up and running, tested it with a meter and an led, but i hoed the 5v out wire to the correct pin hole on the nes, and im not able to test it on a screen yet, but i tried hooking several leds up to the led pinholes on the side of the board and none of them lit up. Should i be worried? Thanks
Aug 9, 2010. 2:54 PMTheLHP says:
I tried the LEDs both ways, and yea the RF box is off, and i made sure the nes is getting 5v and i even tried hooking it up to the display and nothing happened. Should i be worried? Thanks
Aug 5, 2010. 7:03 AMmarioluigi1 says:
I have a huge problem! When I hook it all up to a TV and turn it on, The TV just makes a deep humming noise and no picture comes on at all! When I put a game in at a certain angle however, I often get a very short, fast tune or a single note followed by deep humming again. (Still no picture) :( I didn't make the regulator though as my batteries give out 6V. I do not think that this is the problem though, but I have NO IDEA what the problem is with it!!! Please help :(
Jul 8, 2010. 7:05 AMderyan97 says:
hey i was just wondering whats the voltage on the capasitors cuse they say 45v at 100uf or something so does it matter or i should go with higher or lower voltage please reply
1-40 of 62next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
266
Author:1up(ModRetro)
Sometimes my Instructables are few and far between, but I try to make them as well as I can. Hopefully you can be inspired or helped by the content in them!
