3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Portable Game System
Step 23Brightness Mod (If you did the LED mod)
What you need:
A small piece of wire
Soldering Iron
This is for if you did the LED mod and noticed the screen isn't very bright. There is an easy fix to this, but the contrast is slightly affected.
Turn the PSone screen board over. Find the chip in the very middle surrounded by a bunch of small surface mount components. Find the one that is called "CV23". This is the brightness control.
What we want to do is jump that component. You could remove it and put a piece of solder in it's place, but it's better to jump it; in case it is too bright for you, you can just undo it.
Simply take a small section of wire with the ends stripped, and solder one end to the bottom side of CV23 and the other side to the top of it, so that it essentially isn't there. Enjoy your brighter screen!
5 comments
Jan 16, 2011. 11:33 PMnezamex82 says:
HELLO! I LIKE WHAT U DID DO YOU THINK I CAN USE A LCD SCREEN FROM MY USED LAPTOP?CAN I DO THE SAME STEPS ?
Jan 17, 2011. 5:29 PMProgMetalMan says:
AND PLEASE DON'T USE CAPS LOCK! It gives off the impression that you're yelling.
Jan 17, 2011. 5:27 PMProgMetalMan says:
No, it probably can't accept input from anything other than the laptop.
That, and it will likely be too big.
Nov 14, 2010. 12:27 PMjelte1234 says:
what if you would put in a potentiometer? would that make it regulatable? or is there a way to make the original buttons work?
May 28, 2010. 5:15 AMtechnoguy94 says:
What if you used a small switch, so you could switch from normal to bright and back at any time?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
266
Author:1up(ModRetro)
Sometimes my Instructables are few and far between, but I try to make them as well as I can. Hopefully you can be inspired or helped by the content in them!
