3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Portable Game System
Step 24Antiglare Mod for the PSone Screen
  • last photo ←
This Step Is Optional
What you need:
Paper Towels
Water
X-Acto Knife
Patience
This is where you can remove what is called the "antiglare" layer on the PSone screen. This layer is a thin, diffused piece of plastic. It is used to keep the screen from reflecting a lot of light. Removing it takes off any scratches, and makes the colors more vibrant and the screen brighter. Since I did not do this mod myself, I have no pics to explain this procedure with. Instead, here are pictures and documentation from another person. These are courtesy of Hailrazer of the benheck.com forums. The pictures have captions on them with the steps embedded.
Quoted directly from Hailrazer's topic (Link here):
"Some of you may know this already but I thought I'd pass this on to any who might like to know.
If you're like me sometimes while working on the Psone screen you might scratch it up or smudge it a bit. Also you might notice that it's a bit murky looking. Like this :
(Picture 1)
Well on the top of the Lcd is a Antiglare layer. It is a protective layer that is on top of the Lcd that also serves the purpose of reducing glare. But it has the side effect of muting colors and reducing brightness. The solution. TAKE IT OFF !!
The easiest way to do this is called the "Water Soak" method.
Here's what you do. Starting with the Ps1 screen stripped down to this:
(Picture 2)
1. Remove the metal bracket holding the Lcd to the backlight. Ben has a tutorial on this already so I'll spare you the details. (Note : This can be done without removing the metal bracket, it just will take more effort later)
2. Remove the Lcd from the backlight (by just lifting it off) and set it on a towel or similar surface. The pic shows leaving it on the backlight but I have changed this. If you take the Lcd off the backlight then you don't have to wait as long to allow the backlight to dry after performing the mod.
(Picture 3)
3. Take a couple of paper towels and layer them in 3-4 layers. Cut the paper towels where they cover the LCD precisely and lay them on the Lcd.
4. Wet the paper towels by dripping water on them slowly. You want enough water on them for the paper towels to be soaked, but not so much that the water is dripping over the edges into the backlight. The paper towels can hang over the top edge but DO NOT let them hang over the bottom edge. You don't want the ffc's getting wet for a long time. Also try to get most of the bubbles smoothed out of the paper towels. You want the wet paper towels to make a good contact with the Lcd.
(Picture 4)
5. Leave paper towels soaking for 4 hours. I repeat 4 hours. Do not soak for less than 4 hours. You want the antiglare to come up in one piece without any sticking or glue residue so it is imperative you wait for 4 hours.
6. Remove paper towels.
7. On top of the Lcd you will notice a thin layer that is covering it. This is the polarizer/Antiglare layer. The polarizer is on top of the Lcd and it is the thicker layer with a tinted look. the antiglare layer is on top of it. It is paper thin and is clear/slightly cloudy. We are going to use the razor and pick at the edge of this dual layer. The antiglare layer will be very thin and will look like a piece of clear but slightly cloudy saran wrap. It will peel off very easily. If the piece you are pulling up is tinted and stiff STOP, you are pulling up the polarizer layer and this will render the screen useless. Once you get the edge of the antiglare up , pull it off slowly in one motion. After the antiglare is removed you can wipe off the excess water with a lint free cloth like an eyeglass cleaning cloth.
(Picture 5)
This is what the removed Antiglare looks like :
(Picture 6)
8. After removing the antiglare there is nothing else to do but make sure the Lcd is totally dry and water free , remember water+electronics=BAD. Re-assemble and reconnect the panel after it is dry and enjoy a scratch-free screen with better brightness and colors.
(Picture 7)
And here's a pic of before and after. It's hard to tell the differences when not holding it in your hands. But there is less of a dull look , colors are more vibrant, and better focus.
(Picture 8)
Also like I said if you accidentally scratch or scuff your screen , this mod will fix that. :)"
5 comments
Dec 12, 2010. 12:14 AMbeastguy says:
Dec 11, 2010. 10:30 PMbeastguy says:
Is it ok if I let it soak for 5-6 hours or over night for saftey?
Jan 27, 2009. 6:19 PMfriggs26 says:
hey i was wondering if this step was manditory or if i could just skip it???
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
266
Author:1up(ModRetro)
Sometimes my Instructables are few and far between, but I try to make them as well as I can. Hopefully you can be inspired or helped by the content in them!
