Step 31Putting Together the Case
Your pieces of acrylic (Including the one with the button holes cut in it)
Acrylic glue
Patience and a place for the glue to set
Now, when I put this together, I was at my dad's house and did not have my camera. I am so sorry. :( The most I can provide you with is pictures of it completed and instructions. Oh, and one more thing. Make sure you take off the protective sheet before you glue the pieces of acrylic together.
Lay your front piece face-down on a soft cloth.
Take one of your top/bottom pieces and spread glue on the bottom side of it. Press it onto the front panel.
Before the glue hardens, take one of the left/right pieces and put glue on the bottom and side of it. Press the bottom onto the front plate, and the side onto the other piece you just glued. This way, you can make sure the pieces are at right angles.
Glue the other two pieces in in the same fashion. DON'T GLUE ON THE BACK PANEL! If you do this, you can't put stuff inside it. Duh. :P
Allow 24hrs for it to dry and cure before you do any more work on it.
Add Comment
