3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Portable Game System
Step 34Installing the Components - NES Board
What you need:
NES Board
Screws (and their nuts)
Small right angle brackets
Washers for your screws
Drill with drill bits
Dremel with plastic cutting bit
Hot glue gun
INSTALL BRACKETS TO HOLD THE BOARD
To hold in the NES board, I needed some kind of small right-angle bracket. Luckily, my hardware store had some that were suitable for my needs.
Install the right-angle brackets on the holes that were already in the NES board. See picture one.
MARK RIGHT-ANGLE BRACKET HOLES
Place a piece of cardboard over the existing components and place the NES board on top of that. Mark where the holes on the right-angle brackets are, then drill those out to match the diameter of the screws you'll be using. The reason for the cardboard is to space the NES board away from the rest of the stuff. You don't want it too close or stuff might short, too far and you've got a lot of wasted space.
TEMPORARILY INSTALL THE NES BOARD
Using screws and nuts for spacers (I couldn't find spacers that size), install the NES board. It's a good idea to use washers for this, because there will be a LOT of pressure on these areas. See the pictures, they explain it better than I can.
You probably noticed that there is no hole for the cartridge slot. Well, take an NES game (make sure the NES board is installed already.), and hold the bottom of it firmly to the top of the case, right on top of the cartridge slot. Use a Sharpie to trace around the NES cartridge. Take off the cartridge and check where you marked your Sharpie. Is it centered RIGHT over the cart slot? If not, use a pink school eraser to take off the Sharpie, and do it again.
DISASSEMBLE THE PORTABLE
Now, here comes the fun part. (Not really, this part sucks.) Take apart your portable so far. Yes, that's right. Take out the NES board, controller boards, and screen. You need the empty case again. Get a piece of cardboard about the size of the inside of the case and shove it in there. You want to protect the screen area while you are Dremeling and filing.
CUT THE CARTRIDGE HOLE
Get your Dremel with the plastic cutting bit and start on the cartridge slot hole. Use the same procedure as the D-Pad hole. Start in the middle, then go to the outside. Dremel just inside the marks you made.
FILE THE HOLE DOWN
Once you have the plastic cut out, get your file and smooth out the hole. Use a square file for the corners. Constantly check the fit of the NES cartridge. Once you think you are done, install the NES board but not anything else. Plug in the cartridge (make sure it's facing the right way! (Label faces up, and so do all the components on the NES board)), and make sure everything fits okay.
INSTALL THE SWITCHES
Before you put everything back in, go and do the next step, which is installing the switches. Once you get that done, you can then put the other components back in.
INSTALL THE SPEAKER
It might also be a good idea to install the speaker. :P Drill a bunch of holes, and use a couple dabs of hot glue to hold it in. See the last picture.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
266
Author:1up(ModRetro)
Sometimes my Instructables are few and far between, but I try to make them as well as I can. Hopefully you can be inspired or helped by the content in them!
