3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Portable Game System
Step 37Holy Crap! You've made a Portable Game System!
It's wonderful, isn't it? You finished your very first portable. Why do I say first? Well, in a few days, after you've been playing your handheld 24/7, you realize your life feels empty. You've just gotta make another! These things are addicting, aren't they?
If you think your portable isn't so hot, well, I certainly didn't make a perfect portable, either. Let me list all the flaws of my NES portable:
- There is a big scratch under the screen's plastic. This happened because I didn't put down a piece of cardboard when I was making the cartridge hole.
- The screen's buttons are quite hard to press. I don't know why, but I'll probably fix it sometime.
- The power switch ALMOST hits the cartridge when you flip it on. Not a huge problem, but it's a bit unpleasing aesthetically.
- The cartridge droops downward. I made the cartridge hole too big.
- Some of the button holes for the A/B Start/Select buttons are way bigger that they need to be.
- There is a huge scratch next to the select button. I slipped when I was making the hole bigger with my Dremel.
- There are a few chips in the plastic where I drilled holes.
- The cartridge hole is not straight at all. The sides curve a bit.
- The D-Pad hole is pretty bad. It's hard to see with a transparent case, but there are a few parts that are bigger than they need to be.
- A couple spots where I used hot glue look bad because I used too much.
That's it. I didn't make a horrible portable, but I just need to make sure I don't make these mistakes in my next portable. ;)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
266
Author:1up(ModRetro)
Sometimes my Instructables are few and far between, but I try to make them as well as I can. Hopefully you can be inspired or helped by the content in them!
