3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Portable Game System
Step 7Test your Setup
Test your Setup
To be sure everything works, you should hook everything up without modifying anything. Below is a picture of my setup. The battery is connected with alligator clips. This step is mainly to be sure all your stuff works fine, and that the battery can handle the mA draw.
If your batteries are more then 8.5v, then you MUST go and do step 17 before hooking your screen to your batteries. You will fry your screen if you don't!
36 comments
Aug 22, 2011. 5:06 AMviper56 says:
I want to know about these green chips in the picture??
Thank,,,,
Aug 9, 2011. 9:28 PMsea34567 says:
okay btw i got a new screen and yeah i don't wanna fry it so if i fried the screen by connecting to wires together should i be worried about the battery frying the screen and i charged it so can the 7.2 volts go up to 8.5 volts
Aug 9, 2011. 9:22 PMsea34567 says:
question i accitendly touch to wires together and fried my screen with the battery then i charged it I'm afraid to test the setup so what I'm saying is i don't wanna fry my screen again so should i buy a new battery or still use the old one
Jul 6, 2011. 7:47 PMdwhitslar says:
mine 10.8 volts 4000mAh li-ion battery from a toshiba laptop
Dec 16, 2010. 2:43 AMFn4tic says:
after i tested the psone screen with the ps1 ac adapter (that worked) i wanted to power the screen with my 8,4V NiMH batterie, but after that the screen never worked again. what i could make wrong?
Mar 28, 2011. 1:30 AMMedliDoubleStar says:
8.4 v is close to 8.5, so I think you fried your screen.
Jan 15, 2011. 10:34 AMheiszer says:
I am trying to figure out how to hook up my screen from my portable dvd player that i removed the disc reading system within and i am not sure how to hook it up to my console. they boht run off the wall power so im not worried about that just yet. please tell me how to fix my setup.
Aug 27, 2010. 4:47 PMthegeniusdude says:
a few quick questions: assuming I only need a battery for the portable screen, and I can use standard house power for the main console. should i still use such a high-cost battery, or could I go with cheaper ones? also, I am making my Dreamcast portable. I do not want to open it at all. i just want it as-is. do you know of any batteries I could use that are small enough to fit inside the casing of a Dreamcast modem (4" long, 1.75" tall, 0.75" thin) also, how would I be able to connect a DC power cord (i mean dc power, not the dreamcast power cord :P) to the battery itself? I would greatly appreciate any help!
Sep 12, 2010. 7:18 AMnorthernmagnet says:
isn't there a device that plugs into the male a/c cable (house plug) that runs it off battery? : \
Sep 2, 2010. 12:38 AMmarioluigi1 says:
Ok... I tested the voltage with a voltmeter before I hooked the battery up and the voltage was fine. Then I tested it again after I hooked it up and the voltage had dropped by about half!!!??? Is this normal or am I just being paranoid? :) Thanks.
Aug 8, 2010. 6:56 PMjreuse says:
How many volts/mA is the battery that you used? And are you powering both the nes and your screen from the battery? Thanks
Aug 8, 2010. 11:26 PMjreuse says:
The reason i ask is because i dont get how a 7.5v battery can supply power to both the screen and nes. You said the nes takes 5v so does that mean your screen is only drawing 2.5v? I am very confused...
Aug 9, 2010. 12:56 PMjreuse says:
Ok thank you so much. That totally makes more sense now =)
Jul 12, 2009. 2:54 PMSkipperOf says:
I tested my NES before hand, and it worked. I took it apart, shrunk the board and tested it with the RF box still on, and it worked. I took it off, and hooked up only the audio to a TV I had when it was on, but I didn't get any audio. I didn't have the video signal hooked up yet. Should I be worried?
Aug 10, 2009. 6:42 PMLetsExplodeSomething says:
if it takes only 5 volts couldn't you power off of a usb connection? not that would be ideal at all unless you wanted to recharge it from ur laptop on the go
Oct 2, 2009. 2:48 PMmason0190 says:
And build one of thise nifty Altoids usb rechargers ;)
Aug 10, 2009. 9:24 PMBasement_Modder says:
Nope. A USB connection does not provide enough amps. Also- the PSone screen needs at least 6.5v to run.
Aug 11, 2009. 8:26 AMLetsExplodeSomething says:
ok thought it might make it a little more portable to be able to charge from a laptop
Aug 10, 2009. 6:35 PMcjmassey08 says:
i dont quite understand how to connect everything together. could you help me out and tell me exactly what you used to connect them?
Solder and wire.
Jul 10, 2009. 3:17 PMsea34567 says:
buy the circuit board
Jul 9, 2009. 5:28 AMsea34567 says:
where can i buy this
Jul 8, 2009. 4:44 PMsea34567 says:
what is that green thing attached to the screen where the voltage supply conects
Jul 7, 2009. 2:02 PMsea34567 says:
can you give me intructions how to test the setup because i don't know how
Nov 30, 2008. 3:08 PMnintendocrazzy says:
how long would a cuple of 9v conventional battorys last for this Nes portible?
Nov 30, 2008. 5:41 PMdehlome says:
not very long i supose
Dec 1, 2008. 10:28 AMnintendocrazzy says:
are you bulding this portible?
Dec 1, 2008. 4:29 PMdehlome says:
i am building this portable
Dec 4, 2008. 3:31 PMnintendocrazzy says:
sweet how far are you in completing it i have not started yet i want to get everythng first
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
266
Author:1up(ModRetro)
Sometimes my Instructables are few and far between, but I try to make them as well as I can. Hopefully you can be inspired or helped by the content in them!
