Step 8Disassemble the System
Phillips screwdriver
NES
Once everything is assured to be working, you need to take apart the system. The NES is very easy to take apart. All you need is a phillips screwdriver.
Flip the NES over and remove the 6 screws on the bottom and the 2 for the controller ports.
Flip it back over, remove the top, and take out the 5 screws holding the shielding in.
Take the shielding off, and unscrew the 6 screws holding the cartridge mechanism in.
Remove the cartridge mechanism (you may have to slide it forward a bit) and take out the 2 screws near the RF box in the upper right corner.
Unplug the two player ports and the power/reset plug.
Pull out the NES board.
Congratulations! You now have your NES taken apart. If you want, test it to make sure it all works fine.
I am trying to save money on a multi-system portable so do you think famiclones are good for modding
