Stuff you need:
Flash (I'm using CS3, but you can use MX-CS4)
A computer
A trial of flash/full copy (which you can get here)
Obviously, open Flash and make a new Flash file. I'm using Actionscript 2, BTW.
Remove these ads by
Signing UpStep 1Adding Layers
Next, we need to add one Keyframe to the Actions layer, and one Frame to the other layer.
Then take the Text tool(T), and select Dynamic Text from the drop-down box in the properties box, it probably has "Static Text" selected already. Now, draw a rectangle with the Rectangle tool(R). make sure fill isn't white.
Make the fill of the rectangle you just made a Movie Clip by clicking on it once and and pressing F8. Name it, and make sure "Movie Clip" is selected and the Registration Point is in the top left before you press OK. THIS PART IS IMPORTANT Select the movie clip you made, and in the properties box, you'll see a text box that says "Instance name". Type in loadBar. Press Enter.
Then, select the Dynamic Text box you made earlier, and go down to the Properties Box. You should see the instance name text box again, click on it. This time, type in textBox. Press Enter.
8
comments
Add Comment
karossii
says:
Add Comment
