Picture of How to Make a Push Pin Portrait
We are going to make photorealistic push pin portraits.
We will be guided in our pin placement by a low resolution indexed color gif image we will create in Photoshop. The .gif will use a limited palette restricted only to those colors in which the plastic push pins come.
This tutorial assumes you have some access to and basic understanding of Adobe Photoshop.
Step 1: Select a photograph
Picture of Select a photograph
Using Photoshop, adjust your image so that it contains a nice range of colors and values, with no large areas of pure black or white or any other color. This will give you a dappled variety of push pin colors across the finished artwork, rather than large, boring expanses of a single hue.
I'm using a photo I took of a woman who sells her hats and headdresses on the internet.
Step 2: Decide the final dimensions of your work in inches
Picture of Decide the final dimensions of your work in inches
I'd like my final artwork to by 45" wide by 60" tall. My push pins are 0.5" in diameter, so I'll need to shrink my photo to 90 pixels x 120 pixels where each pixel will ultimately represent a push pin. That means I'll have 90 x 120 = 10,800 pins total.
Step 3: Convert the photo to a .gif of limited colors
Picture of Convert the photo to a .gif of limited colors
First determine the colors you intend to use. I have chosen black, white, red, yellow, and blue, for a total of 5 colors. I have omitted green from my artwork, even though push pins often come in green Notice my photo contains regions that appear green. Those regions will appear green in the finished artwork as well, even without the use of green pins, thanks to the color mixing that occurs in a dithered .gif
I've prepared a video that demonstrates in detail the process of producing a push pin palette .gif image.
Step 4: Count pixels of each color so you can buy pins accordingly
Picture of Count pixels of each color so you can buy pins accordingly
Your histogram can count the number of pixels selected.
Using your magic wand tool set to non-contiguous regions, tolerance = 0, visit your tiny 90 x 120 .gif and select each color in turn.
Record the count reported by the histogram for each color, That's ho wmany push pins of that color you'll need.
1-40 of 48Next »
dhruv97 months ago
Hey, could you please help me and teach me exactly how this pattern is achieved to eliminate space betweenpins
http://f.fastcompany.net/multisite_files/codesign/...
your help is greatly appreciated :)
digitalArtform (author)  dhruv97 months ago
I haven't thought about it too carefully, but my initial reaction is you could shift every other line 0.5 pushpins to one side, do the process, and shift the resulting large pixels back into their original position. That should create a brick pattern. I talk a bit about that here:
http://www.digitalartform.com/archives/2009/05/dis...
You might also look at making a hexagonal mosaic before using the indexed color to limit the palette. I talk a bit about hexagonal mosaics here:
http://www.digitalartform.com/archives/2009/06/hex...
pygmypuff8 months ago
Hello DigitalArtForm,
I followed through your whole tutorial but I'm having problems with step 5.
See, I'm trying to have an A1 sized pushpin art.
After blowing up the image size by 1600% ( am I supposed to change the pixel dimensions or the document size? ) , what do I do next?
I can't seem to follow your 1:1 guide after that cause when I change the document size to my desired height and width, the pixel dimensions will automatically start to change the value too.
I would like to ask how can I make sure that my image is my required size and that the pushpin pixels are the right size to the pushpins when printed out.
Please help me out by making clear if I am supposed to firstly, change the image size or the canvas size, and in the image size option, am i supposed to change the pixel dimensions or the document size.
For your information, my pushpin diameter is 0.31 inches.
syben1 year ago
Hello digitalArtform,
Im working on trying to make my own pushpin portrait of freddie mercury, but am struggling with the fact that I don't want the final result to be as big as yours. Im from Europe so we use CM for sizes here. I want to have a final result of 60 CM x 90 CM, but don't know if the visual aspect of the final result will be as good as yours, as its a smaller size. Is there a minimum size to at least get to still make it look good?
Also I am struggling to understand step 5 of your tutorial. Is it necessary to convert the image back to a RGB image? I just made the width and length of the document size the same amount as my pinboard will be. Or is this not a good manner of working?
Please help me out because I really can't wait to get started.
Thanks in advance,
Greets from Syben from The Netherlands.
P.S. Where did you buy your pushpins and how much did you pay for them all if I may know?
digitalArtform (author)  syben1 year ago
60 cm x 90 cm is about 2 feet x 3 feet. Pushpins over here are about 0.5 inches, so you'd end up with 48 pins across x 72 pins high, more or less. That might be enogh detail if you tune the vlaues and hues of your input image to optimize your result. (in other words: make it look good)
You can preview the result by blowing it up in photoshop. Nearest neighbor setting. You will need to go back to RGB mode. Good catch.
This is mainly a tutorial on how to make a color guide. I never actually made a finished pushpin portrait. I illustrated it with CG. If you scroll through the comments you'll find where I posted the wireframe.
furbman1 year ago
where is good, cheap place to bulk push pins?
digitalArtform (author) 1 year ago
beautiful work. beautiful daughter.
lorentnum11 year ago
from far away
Here it is
Hi digital,
Thank you so much for your instructions. I am attaching a photo of the final work. It's a picture of my daughter.
Amazing! I found a way to make the push pins to be arranged in equilateral triangles. You can see this blog:
http://ccpalettes.wordpress.com/2013/01/05/how-to-make-a-push-pin-image-in-an-arrangement-of-equilateral-triangles/
I have a page on pre-distorting images you might like:
http://www.digitalartform.com/archives/2009/05/distort_photosh.html
Hello, can you please talk me through this step. I am having trouble figuring out how to shrink my photo. Where do I go in photoshop to do this?
digitalArtform (author)  Sasquatch391 year ago
In the top bar you'll find an entry called "Image." Under that, select "Image Size..." and in the option box that appears enter your desired height and width in pixels.
How much does this usually cost? Thanks
wow, this is amazing!! Do you happen to know how to arrange the pins in a staggered fashion instead of in a row. Looks like the resolution would improve if you do that.
Here is a link of artist Eric Daigh doing that.
http://www.fastcodesign.com/1670620/watch-this-guy-draw-pinterests-ceo-using-22765-pushpins#-4
digitalArtform (author)  lorentnum11 year ago
Off the top of my head I'd say the original photo would need to be cut into strips and every other strip offset by the right amount. Then with the picture in its staggered 'ruined' form, go through the process. Finally, 'repair the damage' caused by the staggering and if you do it correctly you should have a brick pattern.
I go into some detail in my web site on the general idea of pre-transforming images, and then untransforming them after applying a filter.
Distort Photoshop Filter Without Distorting Image
marilton2 years ago
impressive work!, ive already made my PS file and i'm about to start the artwork, any recommendations on the base material? and also, any recommendations on keeping the rows straight?
digitalArtform (author)  marilton2 years ago
I don't have a good suggestion for substrate. I'm wondering about painted cork tiles (onto which a faint grid could be made in pencil)
http://www.ehow.com/how_7709329_paint-cork.html
And for a description of how to make a virtual grid (requires more Photoshop expertise) see my response to the third comment.
nogoodnikki2 years ago
finally got it to work , so happy I've only used Photo Shop like twice before so this was its own challenge - thanks cant wait to try it out i think ill use pony beads instead of push pins just a little cheaper
jbrecken2 years ago
What material did you use for the board all the pins got stuck in? And was there a trick to keeping your rows straight?
digitalArtform (author)  jbrecken2 years ago
Also in the Instructable I mention the idea of making the printed placement guide 1:1 scale. I had actually worked out a way to make the spots of color smaller than the pin bases, so they would not be visible, and to put a precise pinhole dot in the center of each color spot so as to make the rows and columns more exact. In the interest of being concise I left it out of the main tutorial, but here is idea:
1) You start with each pixel its own color. Convert the little indexed color image to rgb.
2) Enlarge it a lot, but try to make the enlarging percentage a power of 2. That will keep the squares neat, square, and all the same size. That means enlarge 200%, 400%, 800%, 1600%, 3200%... choose a number like that.
3) When you have it big, make it the exact size you need by making it the inches you need. You can lower the dpi to balance it out. For example:
a) You start with a 88 x 160 indexed color image.
b) enlarge it 3200% (nearest neighbor option). You now have 2816 x 3840 pixel resolution.
c) 88 pushpins at 0.25" per pin is 22". Divide 2816 pixels by 22" to get 128 dpi
d) Set your image to 2816 x 3840 at 22" by 40" at 128 dpi
e) Print that somehow, either in pieces or at a place that makes big expensive large format prints.
4) If you want to add a pattern mask of some kind, do this:
a) Figure out the size of the tile you need to make, define as a pattern, and fill with. You need a square tile that will repeat 88 times across a 2816 pixel wide image so you need to make a 2816 / 88 = 32 pixel wide tile. It's actually obvious that the tile should be 32 pixels wide because each 'pushpin' was originally defined as one tiny pixel, and they were all blown up 3200% so 1 blown up 3200% becomes 32.
b) create a tiny 32 x 32 pixel image.
c) make the best circle you can in it using the pencil tool. Make the circle black on a white background.
d) define it as a pattern. Edit > Define Pattern
e) make a new layer above your master, giant pushpin image and fill with the pattern you just made. Edit > Fill (with pattern)
f) Set the blend mode to screen. Now the squares are all round looking.
5) If you want to make pinpoint guides that will show up on black, white, and every other color...
a) make a black 32 x 32 image with a little white dot in the center
b) define it as a pattern
c) tile it above the master large image
d) set the blend mode to DIFFERENCE or EXCLUSION and the dot will magically be the right color for maximum visibility no matter what color square it lands on.
First off, great instructable! Love it, have many people collecting push pins wherever we can find them!
I have my image already to go, for once we have the thousands of push pins. I just want to make a suggestion to anyone who is trying to attempt to hide the background and also have an exact place where to put the pins.
I used your -able all the way to the end, then when it came time for the enlarging, I edited the image size, to be exactly what the finished size will be, in this case 45" x 55". I then converted back to RGB mode and followed your steps above. This is where it became a little confusing, the rings are not an exact color, rather a mix, so this is what I did differently.
I made the circle using a 50x50 px image. I used the circle marquee, edge to edge, contracted by 2px deleted the center and wham! ok. Then I applied the pattern to a new layer, and this is where it is different. I broke out the wand tool, selected all the white space BETWEEN the circles, and then selected my picture layer and deleted those areas. I am now left with circles of the image, full ones too.
Then, I went back to my 50x50px image and added a white 4px dot to the center, and used your method of overlaying with a DIFFERENCE blend mode. allowing me to see the center of each circle, regardless of color. I then merged all the layers and put it back in to index mode and wham! exact circles of the color with center points ready to have pins applied!
Thanks again for this detailed tut!
This was my result
digitalArtform (author)  windowDude2 years ago
Looks good.
Sounds great, and I hope to see your finished work
The video I made (which is featured in this Instructable) was created primarily to answer a question I had been asked about how to achieve decent photographic color rendition with only 5 colors.
The question was originally asked of me in the comments of this other video of mine
http://www.youtube.com/watch?v=X2BAKm5_Xnc
and you can see we have an extended conversation about it which ends with me thinking that dithered 5-color gif images might be the way to go.
As for the straight rows - they are an illustration - Maxwell Render simulation - and it's easier in that environment to make them straight than to add error to them.
http://www.digitalartform.com/assets/CG_pin_array.jpg
http://www.digitalartform.com/archives/2012/04/push_pin_portra.html
This technique would create a great gift. Thank you!
i really life this and get to this step and then im completely lost is there any way you can do a step by step video -thanks
digitalArtform (author)  nogoodnikki2 years ago
There is a step-by-step video embedded in this step. Can you see it? It's called
Push Pin Portraits using Photoshop and its URL is
http://www.youtube.com/watch?v=USzbw90wOKM
i saw the video im just not grasping how to get it to look like there are less pixels,
i guess its just more trial and error for me
You have to make your image very small -- one pixel per pin -- so you might make it 90 x 120 pixels.
Then you make a gif using Image > Mode > Indexed Color
Zoom into your image for a close look while you work with the indexed color options.
meenzal2 years ago
Very impressive! You've essentially created a 'paint by numbers' method that lets anyone create quality reproductions. It occurred to me you can get different textures with different 'pixels,' eg: thumbtacks, colored press-on dots, and more. Very clever Instructable! Thanks for sharing this!
Lindie2 years ago
Wow! Nice!
mackerous2 years ago
Just what I was looking for! I plan on doing this with bottle caps I've collected, though it might turn out 'interesting' as most are not solid colors. I have by far the more gold than anything and other colors are yellow, blue, red, green and black. I'm hoping to find an image that can work with those colors.
digitalArtform (author)  mackerous2 years ago
You may be surprised by what works. It will be good to experiment - gold bottle caps may be good for making more than just gold areas. Good luck!
use the gold as your yellow, and your image will be unforgettably beautiful. Trust that you can do it - then post a picture. I believe in you.
Oscelot2 years ago
I can't embed images, so here, have a link: http://chzgifs.files.wordpress.com/2012/02/funny-gifs-pin-art.gif
digitalArtform (author)  Oscelot2 years ago
excellent
Exocetid2 years ago
The patience, the patience!!!
(too much for me, you need to build a robot to do this)
1-40 of 48Next »
