How to Make a Quadcopter Drone and Components List
Introduction: How to Make a Quadcopter Drone and Components List
at this time I have published how to make quadcopter
Step 1: Frame
The frame is important because it is where to put the Other Components of Multicopter . Like Mobil , the Frame Body of Multicopter .
Frame type adapted to the needs . For his own material there are various kinds such as PCBs Fiber , Aluminum , Glass Fiber , Carbon , even some made of wood .
Step 2: Motor OR Rotor
Motor is used as the player vane in order homemade quadcopter you can fly and maneuver . There are so many types of motorcycles sold in the market , but there are some things that are required of you noticed. Motor kilovolt be sorted by size , the higher the faster his kV motors also can rotate. Usually when you buy a special bike quadcopter , you will get the specifications such as : how much amperage required ESC and propeller size recommendations .
Step 3: ESC (Electronic Speed Controls)
or Electronic Speed Controls is a component that works set on each motor rotation speed . You need four pieces of ESC are connected to each of the four motors earlier.
Later, the ESC is connected to the battery as a power source via a socket or via power distribution board first. The level of accuracy of motor rotation is very important to maintain the stability quadcopter , so use the appropriate and qualified ESC .
As a recommendation , use ESC contained therein Simonk Firmware , firmware is able to change the refresh rate of the ESC so as to provide instructions per second more than the ESC to the motor
Step 4: Flight Controller
This is the central component of a Quadcopter , in the board Flight Controller on duty there gyroscope sensor for determining the orientation of motion and accelerometer sensor that reads the speed and slope of the quadcopter .
Step 5: Radio Transmitter Dan Receiver
To be more simple , we call it the Remote Controller . If you want to use Flight Controller HobbyKing KK2.0 , at a minimum you should buy a remote controller that has 4 channels .
Usually to control quadcopter , could use 9xR Turnigy brand , the brand is very popular in Indonesia so you will have no trouble in finding this stuff . Turnigy 9xR has 9 channel , so you can use this remote to other projects in the future .
Step 6: Propeller
Better known as Propeller , to create artificial quadcopter you fly , propeller used is 2 pairs pair rotates clockwise and another pair rotates counter-clockwise or so-called pusher .
Step 7: Battery
Typically , quadcopter using the battery types LiPo ( lithium polymer ) , for the project in this article , use a LiPo battery with 3000mAh 3S1P 20C specification . Means the battery capacity is 3000mAh , 3S1P means 3 cell mounted in parallel , with each cell has a 3.7 volt battery means is the voltage of 11.1 volts . while C stands for Capacity, so 20 C with 3000mAh means 20 * 3000 = 60000mAh = 60 A. 60A was issued battery current in a moment .
The greater capacity of the battery , the greater its enormous size , the larger the size of the batteries will add to the load received by quadcopter .
Step 8: Charger
LiPo battery charging process has a difficult process because the charger must charge and discharega on some cell in a LiPo battery at the same time .
The most popular and widely available on the market are trademarks of IMAX B6 Lipo Balance Charger , because it is believed to have the stability of charging .
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    If we were to choose between a carbon and a glass frame which would be you pick? State your answer with the correct reason of you choice ?
    i love this quad copter...amazing!!!
    Which one is more easier?? this post or DIY Quadcopter for beginners??
    Hope you succes make it her!
    Thanks for sharing the quad copter tutorial. It is always more fun to build your own than to just buy one.
    thank's for ur knowledge.
    i want to make it this...
