My grandmother made a Raggedy Ann doll for me when I was little, and I'll never forget the details she put into it. I always appreciated the layering of clothing, which made it fun to dress.
Since the craft contest is sponsored by Singer and Lion Brand, I wanted to make something that incorporated sewing and yarn.
Step 1: Making the Body
Making the doll involves a lot of steps, but none of them are difficult. I made my own pattern using geometric shapes of rectangles, circles, and ovals.
You will need about a yard of whatever color material you wish to use for the body.
I suggest a lower thread-count fabric, since muslin makes it difficult to get the yarn/hair through.
Pin the pattern to the fabric, trace around the edges, and cut about 1/2 inch further out than the traced line.
Cut 4 arms, 4 legs, and 2 head/bodies.
(Whenever you see my pen pointing at the fabric, it means to sew that area.)
Sew 2pieces of the arm to make one. Do the same for the other arm, and for the legs.
TIP: When rounding a corner, leave the needle of the sewing machine down, lift the foot, turn the fabric, lower the foot, and turn.
Sew the head and body, leaving open two holes in the sides for the arms to fit in, and the bottom open.
Once the pieces are finished, notch the corners to keep it from gathering around the curves when you turn it inside out.
Step 3: Hair
I used the Vanna's Choice Cranberry for the main hair. For the highlights, I used Lion's Suede Scarlet.
You'll need a needle with a large eye to get the yarn threaded. Don't double thread. If you can't get the needle and yarn through, use a flat, rubber jar opener to yank it through.
Pull the yarn almost to the end, leaving about 2.5 inches of length or longer. Cut the yarn, and tie it in a knot.
I made this doll's hair thick, but you don't really need to. Work your way in a circle around the back of her head until it's filled in. Once finished, take the suede yarn and pull through some highlights.
Step 4: Face
Using a pencil and white eraser, draw geometric shapes for the face. The eyes and cheeks can be the same size. The nose is a simple triangle. I used a large jar lid to trace the smile from one cheek to the other. If you mess up, erase with the white eraser.
Use embroidery thread and the most basic stitch to go around your shapes.
I hid the knot of the thread in the hair, and pulled the thread through to the face. I tied the end in the hair when I was finished.
Step 5: Clothing
Ok, I admidt, this is really overkill when it comes to the clothes.
To save time, you can always make the legs out of striped material. I decided to make socks, bloomers, a petticoat, dress, and apron.
I really have trouble reading patterns, so for the clothing, I used pieces from several doll dress patterns, and stuffed animal patterns. I took out the complicated pieces and used the basic ones.
Socks: Use the same pattern you used on the legs, but add a little more to the sides.
Step 6: Lay Out the Pieces
Layer your pieces to see if the materials look good together. If not, cut new pieces.
Step 8: Bloomers
These are a little tricky to make. Look for the pen to show where the seams should be.
Sew two of the 4 pieces together like the picture shows. This will be the upper part of the pants. Do the same to the other 2 pieces.
Iron the top edges, leaving enough room to pull elastic through.
With both pieces facing inside-out, sew the sides together.
Turn the pants sideways; iron the bottoms of the legs, and sew lace on the outside edge.
Now turn the pants back to the normal position, and sew the inner parts of the legs.
Using a safety pin, pull elastic through the folded top edge. Pull to make it snug, and sew the elastic ends together.
Step 9: Petticoat
The petticoat, bottom of the dress, and apron all have the same basic pattern. This pattern is placed on the fold, and then cut. It makes 1 front or back piece.
Cut 2 pieces, iron a fold on the bottom, and a larger fold on the top for elastic to go through.
Sew lace along the bottom of the front and back. (Right sides)
Sew the pieces together, wrong sides facing toward you.
Sew the fold on the top, and pull the elastic through. Sew the ends of the elastic and put it on the doll.
Step 10: The Dress
Follow the pictures and the yellow boxes to help with this portion.
The shirt has a front and back. Both sections will need to be sewn around the neck. Normally, there is another piece to sew on called the yoke. I were making a dress for me, I'd try to use it, but this is a doll, so just folding the neck a little, ironing it, and sewing it is enough.
The back piece needs to be cut in the middle so the doll's head can fit through. Those edges will be turned inward, ironed, and sewn. Sew on a small piece of velcro to both sides, or use a hook clasp.
Sew the shoulders together, and the sides. Leave the bottom edge raw for now.
Take one of the sleeves, and sew lace to the bottom of it before sewing up the side.
Match up the top of the sleeve to the top of the shirt and sew it enough to hold it together. Do the same for the armpit area. Once it looks straight, sew all the way around.
Prepare the skirt the same way you did the petticoat, except for the top fold. Do not iron a fold. BASTE (use the largest stitch on the sewing machine) across the top of the skirt. Go all the way around. Carefully pull one end of the thread, and gather the material evenly. Tie off the ends.
Sew (right sides facing each other) the shirt to the skirt, being careful not to sew folds in to the material. I've had to take a seam ripper and undo this before. You may want to try it on a scrap piece first.
Turn the dress right side out.
Step 11: Apron
The pattern for the apron is the same as the skirt and petticoat, except that it has a curved notch cut on the top sides.
Prepare the apron the same way as you did the petticoat.
Iron the curved notches, and sew the fold, but don't sew the notches to each other.
Take one of the four 6"x 2" pieces, iron thre of the edges, and sew around the edges. Sew lace to the top edge.
Cut a 6" piece of elastic.
Sew the end to the skirt, hold it securely in the sewing machine, and stetch it as far as it will go. Pull on the portion that has already been sewn so the elastic is stretched.
Sew the 6" piece to the newly gathered skirt, right sides together.
Repete this process for the back of the skirt, or just leave the 6" piece off. You could sew elastic to it, and cover the seams with lace if you didn't want to mess with the top of the apron.
Take the remaining 2 pieces of 6" x 2" material, fold in thirds, and iron. Sew a zig-zag stitch down the middle to secure it.
Sew a piece of lace in the middle to cover the stitching.
Sew the straps to the top sections on the front and back of the apron.
Turn right-side out.
You can glue a wooden sunflower on the front, embroider a design, or use an iron-on patch for decorations.
Step 12: Shoes
The shoes are optional. I used black felt because it sews easily and can be decorated with embroidery, buttons, or fabric paint.
Cut 2 soles (ovals, and 4 of the side of the shoe.
Sew the back sides together, then along the top of the toe, down to the bottom.
Tack the sole to the back of the shoe, and the front. If it's straight, sew around the edge.
Turn inside out, and sew on fake laces with embroidery thread.
Sorry for these photos. The camera wasn't cooperating with me.
Step 13: Finished
Give her hair an even trim, glue on the flower, prop her up, and hope the camera will take a good picture.
I made another doll with a snoopy outfit and a much more complicated outfit. She has a Snoopy embroidered on her apron.
the_lonely_snake says: Feb 7, 2012. 8:37 AM
it;s so beautiful am gonna cry :) ,i really wished i knwe how to sew and do such stuff
Very Interesting (author) in reply to the_lonely_snakeDec 15, 2012. 10:56 PM
Check out this tutorial; it's a great way to learn and make something pretty. http://www.instructables.com/id/Frabric-Flowers-Easy-Tutorial/
NanaChell says: Dec 10, 2012. 1:16 PM
Thank you so much for the instructions on the doll's hair! I am using a purchased pattern to make Raggedy Ann and Andy dolls for my granddaughter and the way it says to do the hair is just impossible. Your instructions make much more sense and I can now finish the dolls. PS-- your doll in the photos is just adorable :)
Very Interesting (author) in reply to NanaChellDec 15, 2012. 10:39 PM
Thank you :-)
hrachiele says: Dec 18, 2011. 5:05 PM
Thank you for your Instructable. I used it for inspiration for a doll that I'll be giving as a Christmas gift. I will admit that I cheated a little bit, at least when it came to the doll's clothing. I bought a 3T dress and made my doll pattern so that the doll would fit the dress. It worked out quite well. For added cuteness, I also bought a matching dress small enough to fit the child who will receive the doll.
The nose looks a little funny in photographs because I put a small piece of fabric beneath the area where I added the French knots for the nostrils. I felt as though some reinforcement of the fabric might be needed. For subsequent dolls, I am not going to do that.
Very Interesting (author) in reply to hrachieleDec 18, 2011. 6:11 PM
I LOVE it! You did such a good job on her face! Great idea for the dress. Honestly, that was the hardest part of making the doll. She really has a lot of character - how cute!
Cori-Anne says: Aug 31, 2011. 9:41 AM
love the way you explained the directions.. I will be able to get busy on my rag doll.. Hoping it turns out adorable.. Thanks again for the instructions especially for the hair... Keeping fingers crossed..
KittyF says: Jul 28, 2011. 6:17 PM
good job explaining.
Very Interesting (author) in reply to KittyFJul 30, 2011. 10:58 PM
Thanks. If you make one, post a picture of it on here. :)
KittyF says: Jul 28, 2011. 5:48 PM
the nice thing about the original Raggedy Ann and Andy is they never lost their shoes or socks. shoes and socks are the hardest to keep track of for any doll so she was a good doll. LOL
copilarim says: Jul 3, 2011. 8:47 AM
a sunflower princess doll!!:D
sindasilva says: Jun 3, 2010. 2:45 AM
Lovely!
JBeuke says: Dec 20, 2009. 10:34 AM
I can't open the pdf file to print it.  I can't tell the dimensions for the body parts.  Would you send me a pic or the dimensions?  Thanks
Very Interesting (author) in reply to JBeukeJan 11, 2010. 8:10 PM
Legs = 5 inches wide at the foot, 3 inches wide at the calf. 10 inches long.
Arms = 2.5 inches wide. 10 inches long. (Maybe too long, but you can always cut it down.)
Head = 7" in diameter
Body = 8 inches by 7inches wide.
These were not exact amounts, just what looked even on paper. I do remember the arms being too long though. They should be about 7 to 8 inches long.
Ariadne Cantara says: Jan 10, 2010. 4:13 AM
PS. - I think that I accidently clicked on 4,5 instead of the best vote. =( I am so stupid! I'm very sorry!
Ariadne Cantara says: Jan 10, 2010. 4:03 AM
The work is excellent! You're very creative and talanted in doll - making. =)
mcpotts says: Sep 28, 2009. 10:19 AM
found this site, read hair directions, wanted enlarged pic of hair being made, had to join, did join, and now the directions and pix for hair aren't there. What's' up w/that?
Very Interesting (author) in reply to mcpottsSep 28, 2009. 3:48 PM
I'm sorry, but I don't have any control over that. You'll have to ask the site administrator. However, if you have questions about how to make the hair, I'll be happy to answer them.
mcpotts in reply to Very InterestingSep 29, 2009. 9:36 AM
thanks, - am planning on just sewing year in loops, several layers, hoping I can get sewn on w/o sewing through the head itself. Any tips?
Very Interesting (author) in reply to mcpottsSep 29, 2009. 3:14 PM
Ok, so you're using needle & thread to sew the (yarn)hair on? If so, it would definitely be easier. My finger really hurt after a while from pulling the needle through the material. I used one of those rubber jar openers to grip the side of the needle and pull it through. I guess you just need to sew it several times to make sure it's tight, or use a thick quilting thread. Post a picture when you finish; I'd love to see it!
nafisa says: Nov 28, 2008. 10:12 AM
Thank you for all the great info to make this wonderful doll. I am going to make one for my grand-daughter. One comment: wouldn't be easier to embroidery the face before it is stuffed?
Very Interesting (author) in reply to nafisaNov 29, 2008. 9:47 PM
Please post a picture when you finish! I embroidered the face afterwards because I was afraid it would be off-centered, and out of proportion. However, it was very difficult to get the eyelashes straight. I say go ahead and try it before. You can always pin it up tightly to see if it looks good before you sew it. The hair takes a long time, and your fingers will probably hurt, but it's worth it in the end. Good luck!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
