Since the craft contest is sponsored by Singer and Lion Brand, I wanted to make something that incorporated sewing and yarn.
Remove these ads by
Signing UpStep 1Making the Body
You will need about a yard of whatever color material you wish to use for the body.
I suggest a lower thread-count fabric, since muslin makes it difficult to get the yarn/hair through.
Pin the pattern to the fabric, trace around the edges, and cut about 1/2 inch further out than the traced line.
Cut 4 arms, 4 legs, and 2 head/bodies.
(Whenever you see my pen pointing at the fabric, it means to sew that area.)
Sew 2pieces of the arm to make one. Do the same for the other arm, and for the legs.
TIP: When rounding a corner, leave the needle of the sewing machine down, lift the foot, turn the fabric, lower the foot, and turn.
Sew the head and body, leaving open two holes in the sides for the arms to fit in, and the bottom open.
Once the pieces are finished, notch the corners to keep it from gathering around the curves when you turn it inside out.
The nose looks a little funny in photographs because I put a small piece of fabric beneath the area where I added the French knots for the nostrils. I felt as though some reinforcement of the fabric might be needed. For subsequent dolls, I am not going to do that.
Arms = 2.5 inches wide. 10 inches long. (Maybe too long, but you can always cut it down.)
Head = 7" in diameter
Body = 8 inches by 7inches wide.
These were not exact amounts, just what looked even on paper. I do remember the arms being too long though. They should be about 7 to 8 inches long.
