Step 8Fuse the Backing
Once you've pinned the bags into the proper spiral, you're ready to fuse the backing on. The backing is simply another plastic bag split open. You should have a large enough sheet so that there is overlap all around.
First, put the spiral pin-side down on an iron safe surface. Then lay your sheets of plastic bag(s) over the back of the spiral. Note I put the sheets ink side down so that the ink didn't have a chance to transfer to any other surface. Then lay the wax paper on top of the plastic sheet. The plastic bags will melt to the iron! Be sure to only iron on the wax paper Then iron only on the wax paper for a short time. (The time will vary depending on the thickness of each bag. i.e. thinner bags will melt faster) My times varied from a few seconds to a minute or so.
After you pull away the iron and the wax paper, give the rug a minute or so to cool and harden. If you try to move it around while the plastic is still molten, you may ruin the fusing.
Leave all of the overlap, when you continue the spiral the backing will already be partially in place.
Add Comment
