How to Make a Sailor Knot Friendship Bracelet With Pony Beads
3,171
76
8
Published
Introduction: How to Make a Sailor Knot Friendship Bracelet With Pony Beads
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Look for pony bead bracelet patterns? Today, this tutorial is entirely about how to make a bracelet with pony beads. It will be a surprise gift for your friend. Hope you will like it!
Step 1: Materials Needed in Pony Beads Bracelet Patterns:
3MM Colorful Glass Beads
1MM Blue Wax Wire
0.8 MM Black Leather Cord
Lighter
Step 2: Make a Sailor Knot for the Pony Bead Bracelet
1st, cut off four 80cm blue wax cords, keep every two wire as one strand, and fix the ends for convenient weaving;
2nd, tie a sailor knot as picture shows, remember don’t tighten too much;
Step 3:
3rd, cut off two 80cm black leather cords, slide 3mm glass beads on to each leather cord, the number of the beads depends on the sailor knots you made, you can match the colors as you like;
Step 4:
4th, place the beaded string along the sailor knot, and keep it between a strand (two blue wax wires) as picture shows, you can add or reduce beads to fix the sailor knot, do the other bead string in the same method, at last remember to adjust the size of pony bead sailor knot.
Step 5: Finish the Sailor Knot Bracelets With Pony Beads
1st, tie seven snake knots onto each end with one blue cord and one black cord as a strand, one blue cord and one black cord together as the working cord;
2nd, put all the cords together of both ends, then cut off another blue wax wire, and make sevensquare knots, cut off the extra cords and use a lighter to fix the end of the square knots if necessary, tie a knot at every end of cord.
Step 6: Here Is the Final Look of the Sailor Knot Bracelets With Pony Beads:
Good job! This pony bead bracelet patterns have been finished! Although it’s easy to make, the result is so fab! You can make such sailor knot bracelets with pony beads for yourself or your close friend. Just have a try!
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    8 Comments
    Hahaah, thanks so much!
    I'm such a fan of your collection and I can't wait to share this with my friends
    Thank you. Nice day~
    If I remember right, the "Sailors knot" is a Carrick Bend - and the one on the underside of the bracelet goes by many names...Cobra Weave, Portuguese Sennet to name but 2
