How to Make a Scary Wooden Fence Picket Skull
30,950
240
38
Published
Introduction: How to Make a Scary Wooden Fence Picket Skull
About: Recently I read that there are over 60 million American households that participate in some form of crafting in a given year. Well, I am one of them . . . . . I love crafting !!! So please enjoy some of my...
Trick and treat your neighbors with this scary wooden skull. Hang it on the fence close to the front door or hang it ON the front door to help greet your trick-or-treaters on Halloween. This project is fairly easy and inexpensive to make. All you need are a couple of power tools and wooden fence pickets to get stared
Step 1: Supplies
1) Fence Pickets - I used Red Cedar (5/8-in x 5-1/2-in x 6-ft) which are about $2.50 each. One picket makes one (1) skull head approximately 18" x 12" in size. You can make smaller skull heads by using smaller fence pickets (5/8 in. x 3-1/2 in. x 6 ft) which are about $1.50 each.
2) Skull pattern
3) Jigsaw
4) Drill and drill bits
5) Eye protection
6) Wood dowel rods
7) Wood glue
Optional:
Small screws
Chain for hanging
Black shelf liner material
Step 2: Capture and Resize Skull Pattern
1) Click on skull pattern above and hit 'print scrn' on your keyboard then copy and paste it into Photoshop (or other photo editors). Resize the image so that the center portion is the size of your fence picket width; 5-1/2 inches for 5/8-in x 5-1/2-in x 6-ft pickets
Full pattern size is about 20'' X 20"
2) Save the file and take it to FedEx Kinkos (or other custom printing establishments) and have the pattern printed
OR
Use the attached Photoshop (psd) file for printing. Just take this file to FedEx Kinkos and they can copy the pattern for printing. Pattern is for the 5-1/2-in wide pickets
FedEx Kinkos charges $0.75 a square foot to print so this should cost around $2.00
Step 3: Trace and Cut
1) Cut out the paper skull pattern and place each piece on the fence picket and trace around it with a black marker
2) Cut out all wood pieces with a jigsaw by following the black marker lines as a guide (make sure to use eye protection for this step)
NOTE : Cutting out the nose can be a bit tricky. I drilled a hole through the center of nose first to allow for the jigsaw blade. No worries if the nose doesn't look like the pattern. I messed up a few times and ended up making a triangular nose instead and it looked great.
Step 4: Skull Head Assembly
1) Draw 6 straight lines across the wood skull pieces with a pencil as noted in diagram
2) Using the jigsaw, cut the dowel rod into 1/2 inch size pieces
3) Using a drill, drill holes into the side of skull pieces about 1/4 inch deep using the pencil lines as guides. This will help keep the drill bit as straight as possible as you drill. This will also help ensure that the holes in both mating pieces line up during assembly
4) Starting with the left skull piece, fill the drilled holes with a small amount of wood glue and place a small dowel rod piece in each of the three holes
5) Fill the three left-center skull holes with glue and fit the two pieces together
6) Repeat steps 4 and 5 for the right skull and center-right skull pieces
NOTE: Drill bit and dowel rod sizes are dependent on wood thickness. Try to make drilled holes no larger that half the thickness of the wood
Step 5: Finished Fence Picket Skull
Here are pictures of the finished product. This one is approximately 18" X 12" in size.
It's a bit large but it looks great on the fence AND it's relatively inexpensive to make !!!
Step 6: Optional Ideas
If you want your skull to have black color (or any other color) behind the eyes, nose and mouth you can add black shelf liner material (or other materials) to the back. Just cut out the liner and screw it to the back. I also added chain to mine for hanging
Step 7: Other Fence Picket Skulls
Here are a few more Fence Picket Skulls that I made.
Some I left 'naked' (raw wood) and others I stained with wood stain.
I also found some old weathered fence pickets and made skulls out of them too.
Halloween Decor Contest 2016
Runner Up in the
5 People Made This Project!
  • Stick It! Contest
    Stick It! Contest
  • Pets Challenge
    Pets Challenge
  • Woodworking Contest
    Woodworking Contest
38 Comments
lol..ur design??? looks nothing like urs..and with teeth?? ur a rip off dude.
I hope ya do and I would love to see them if you make any.
I made three smaller than you did. I used basic 1" x 4" strapping, so they came out 7 1/2" wide x 10 1/2" long. I cut them out with my jigsaw and glued the pieces without dowels. Next time I think I'll just cut them out of plywood. They hang from my tree outside my small shop. Here's a link to my blog: http://followyourheartwoodworking.blogspot.ca/201...
Thanks again Karen!
nice work. They look great ! Thanks for sharing your creations :)
KarenK116, thank you for the creative and well-thought-out instructable. Really strong work, young lady! My 2 year old son, Alton, and I now have our "Whatever We Want Wednesday" project for tomorrow! I'll post pics of the two of us in action tomorrow and am really looking forward to seeing his face light up when he sees the finished product come together. Thank you for helping me blow his mind and for the fun we're going to have re-creating your work. If you accomplish nothing else tomorrow, know that you helped a single father make another wonderful memory to share with his only son. You have my vote.
Jay
Oh you made my day Jay :). Thank you so much for the very kind words. I hope you and your son have a delightful day today making the skull and I can't wait to see the final product. Have fun you two :) :) :) :) :)
Well, we didn't get past the home depot trip - have a few other projects going on and ended up making the materials run our day's activity. 2 year olds make horrible contractors - jobs are never on-schedule and always cost more than the original estimate. But we had a good time shopping and will hit it again this weekend, with pics to follow. Thanks again and good luck!
Yes, those things always happen, especially with a 2 year old. I'm looking forward to your picutures.
Going to make it this weekend. I'm going to use it as a door hanger for Halloween. Instead of using Dowels, I'm going to fasten it to 1/4" plywood, since I have plenty of scrap stock. Keep the excellent ideas coming! :-)
That is an excellent idea Clark !!! Please post some pics ....
This is a great idea! Love the clear and concise directions. Thank you!!
Could add a sensor to it and make the lower jaw move with a servo as well, come to think ot it! Maybe use a Raspberry Pi to have it make a scary laugh as well! :D
That would be awesome .....
Voted for you! I am going to make this! Will post photo when done. I am going to paint the openings with gid paint.
Thanks for the vote. Post up some pics if you make any. I love seeing what everyone does with it
Thanks for the vote and I can't wait to see your creation. I can't wait to see what it looks like painted :)
I kiked this very much! Maybe I´ll try to make one too :). (voted)
