How to Make a Scissor-type Extension Arm
Introduction: How to Make a Scissor-type Extension Arm
Scissor-type extension arm is a common extension device which has relatively short stroke and can extend proportionally, as showed in the picture above.
The displacement of B =the displacement of A x the number of the segments
For instance, the above picture2 shows a 4-segment extension arm, hence the displacement of B can be calculated by using the formula, that is by multiplying A (the stroke change of the slide) by 4.
All these parts are from:
Next is the constructing steps:
Step 1: Build the Drive Part 1
Part List:
1 x Servo
1 x Plate 3x6
3 x Screw M4x8
Step 2: Build the Drive Part 2
Part List:
1 x Beam0824-080
1 x Beam0824-024
2 x Nylon Lock Nut 4mm
2 x Screw M4x22
Step 3: Build the Drive Part 3
Part List:
1 x Plate 45°
1 x Plastic Rivet R4100
Step 4: Build the Drive Part 4
Part List:
1 x Beam0824-080
1 x Screw M4x40
2 x Plastic Spacer 4*7*10
This extension structure
needs to drive thru linear motion, hence we used plate l1 as a guide rail and used plate 45°to transform the circular motion of the servo into linear motion.
Step 5: Build the Drive Part 6
Part List:
2 x Plate I1
4 x Screw M4
4 x Screw M4x14
Note: As showed in the picture 3 in this step, we need to drill a 4mm hole at the end of plate l1
Following the steps, we finished building the drive part.
Step 6: Build Extension Arm 1
Part List:
10 x Plastic Rivet R4100
8 x Beam0808-076
Step 7: Build Extension Arm 2
Part List:
3 x Plastic Rivet R4100
2 x Beam0808-044
Step 8: Repeat Above Building Steps, Then We Got the Structure Below:
Part List:
2 x Beam0808-044
2 x Plastic Rivet R4100
1 x Plastic Spacer 4*7*2
Step 9: Connect the Extension Arm and the Drive Part.
Part List:
2 x Screw M4x30
Several Plastic Spacer 4*7*2
Step 10: Fix Screw Number 1 and Screw Number 2 Separately Into the Hole and Groove of Plate L1, As Showed in Picture Below:
Step 11: Note: the Plastic Spacer Here Is to Parallel Two Plates. the Quantity of Plastic Spacer Used Here Depends on Actual Situation.
Following above building
steps, we finished building the scissor-type extension arm.
This extension arm can be mounted onto Starter, Ultimate, mBot or other Makeblock robots.
learn more:Makeblock
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    I can't find "4 x Screw M4" which screw is that from MakeBlock?
