Introduction: How to Build a Screw-Propelled Vehicles
About: Makeblock was founded in 2012 as the world's first open-source robot and programing platform. With more than 400 mechanical components, electronic modules, and software tools, we are determined to bring meanin…
Recently, surfing on the internet, I found the screw-propelled vehicle invented in the early 20th century very interesting.With strong off-road capability, this vehicle is designed to cope with almost all kinds of landforms, such as snow, swamp, water, desert and forest, except normal asphalt road.During the Space Race of U.S.-Soviet Cold War, such vehicles played a very important role in retrieving the returned space capsule from snowy Siberia.
Looking at those old picture, I can’t help wondering the wild imagination people had.
Well, move on to the topic. As a child growing up with toys, I decided to build a screw-propelled vehicle by myself. I collected all the material I need and start building.
Most parts are from: Makeblock
Step 1:
First, I used the 3D printer to print the special shape of wheel for this vehicle.
Next I prepared the parts
used in this case.
Here is the part list:
2 x Printed Screw Wheel
2 x Beam0824-160
2 x Beam0824-112
4 x Timing Pulley 62T
6 x Timing Pulley Slice 62T B
2 x DC Motor-25
2 x DC Motor-25 Bracket-B
2 x Shaft D4x170mm
4 x Plate 45°
2 x Timing Belt 98XML-123T
4 x Plastic Rivet R4120
4 x Plastic Rivet R4050
4 x Nylon Stud M4x30
2 x Shaft Connector 4mm
4 x Shaft Collar 4mm
4 x Flange Bearing 4*8*3mm
4 x Screw M3x8
6 x Headless Set Screw M3x5
18 x Socket Cap Screw M4x14-Button Head
20 x Socket Cap Screw M4x8-Button Head
1 x Gamepad (Include Receiver)
1 x Me Orion
2 x PH2.0-2P to Stripped-End Cable - 35cm,22AWG
1 x 6P6C RJ25 cable-20cm
1 x USB Host
1 x Battery Holder for (6)AA
Step 2:
Let’s get started.
Build the main car structure first :
Notice: Please make sure these two beam0824 installed in the middle is perpendicular to each other.
Step 3:
The 3D model saved the place for hole and the flange bearing in advance.
Install the flange bearing in the head of the wheel.
Step 4:
Notice: Put the timing
belt onto the timing pulley, then install the wheel onto the car.
Step 5:
Move on to the motor installation. Timing belt in here is for transmission, hence we install the timing pulley and the timing pulley slice onto the motors.
Step 6:
Install the motor in the screw and fasten the timing belt.
Obviously, this screw-propelled vehicle is almost done.
Step 7:
Install the electronic part onto the vehicle. This vehicle is off-road, hence we need to keep the electronic parts higher, away from the ground.
Step 8:
Finished the building of the vehicle. Then we just need to put battery on and use simple Arduino program to get this vehicle started.
Due to printing range of the 3D printer, the wheel of this vehicle is a little short. Hence this vehicle is unable to swim in the water, but are able to run in the sand and mud. It hardly ever snows here, or it will be awesome for this screw-propelled vehicle to run in the snow.
learn more
