How to Make a Simple Breadboard at Home
2,527
19
6
Published
Introduction: How to Make a Simple Breadboard at Home
About: Maker | Open source ❤ | Engineer
This article describes how to make a simple low cost breadboard .you can build an electronic circuit on a bread board without any soldering .best of all it is reusable. This simple breadboard makes it easy to use for creating temporary prototype and experimenting with circuit design .The interesting thing behind this project is that you can build it at home by using easily available parts. The problem with this model is you cannot use ICs .
Step 1:
Materials required for this project is listed below and shown in fig.1:
1. Aluminium foil 2. Foam 3. Adhesive (like fevicol) 4. Utility knife 5. Scissors
Step 2:
Construction and testing:
Step .1: cut the foam in half by using a utility knife as shown in fig.2.
Step 3:
Step.2: cut aluminium foil by using a scissors according to the prototype model shown in fig.3.
Stick aluminium foil pieces in to the foam (fig.4) by using adhesive.
Step 4:
Step.3: A simple circuit diagram for testing the prototype is shown below
Place the electronic components as per the circuit diagram You have successfully made a homemade low cost bread board.
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    • Water Contest
      Water Contest
    6 Discussions
    Nice. This would be a great project for anyone just getting started in electronics. It would really help to illustrate how all the parts are connected.
