How to Make a Simple Dark Sensor Using 555 Timer
1,528
21
Published
Introduction: How to Make a Simple Dark Sensor Using 555 Timer
About: I like making new things from trash. For more cool content please subscribe to my YouTube channel @ https://goo.gl/BHxFf7
In this tutorial i will show you how to make a simple Dark Sensor using 555 timer.
To build your own Dark Sensor using 555 timer you can watch the video embedded in this step or continue reading.
Step 1: Parts List
***Parts List***
1 * 555 Timer
1 * 8 Pin IC Base
1 * LDR
1 * Green LED
2 * 3 Pin Terminal Block
1 * 470 Ohm, 1.5k Ohm, 5.6k Ohm, 15k Ohm
1 * 1N4007
***Purchase or Affiliate Links***
Banggood
555 Timer - https://goo.gl/EnswJk
8 Pin IC Holder - https://goo.gl/FLnYx8
LDR - https://goo.gl/G12VBp
3 Pin Terminal Block - https://goo.gl/8B4rd9
1N4007 - https://goo.gl/4TQQjt
AliExpress
555 Timer - https://goo.gl/6pWLT9
8 Pin IC Holder - https://goo.gl/HHdwv3
LDR - https://goo.gl/xX72SG
3 Pin Terminal Block - https://goo.gl/unNiAk
1N4007 - https://goo.gl/Bs4nYt
Amazon USA & UK
555 Timer - http://amzn.to/2x57Ez1
8 Pin IC Holder - http://amzn.to/2fYDmtw
LDR - http://amzn.to/2vRMXaZ
3 Pin Terminal Block - http://amzn.to/2yZwvnT
1N4007 - http://amzn.to/2zeIFKA
Amazon India
555 Timer - http://amzn.to/2uYlhCs
8 Pin IC Holder - http://amzn.to/2wpQpLx
LDR - http://amzn.to/2vRkdiz
3 Pin Terminal Block - http://amzn.to/2wMzIXh
1N4007 - http://amzn.to/2wMwN0H
Note: all the purchase links provided are affiliate links
If you wish to support my work then you can do by using my affiliate links given below, this way i get small commission for your purchases.
Bangood - https://goo.gl/ZUhRmV
AliExpress - https://goo.gl/jioyhV
Amazon USA - http://amzn.to/2u7ztbP
Amazon UK - http://amzn.to/2wu4nYP
Amazon India - http://amzn.to/2hroLHz
Step 2: Circuit Diagram
I have shared two circuit diagrams : one with the pot & one without the pot
1. One without the pot : for this i determined the value of R2 by trial & error method. This value senses the dark exactly at the time of sunset
2. One with Pot : this gives you the option of changing the sensing according to your convenience at any given point of time
Step 3: Construction
Now assemble the components on a PCB according to the circuit diagram and solder the components.
After soldering check the circuit & power the circuit
For the test results you can watch the video embedded in the first page or click here
Thank you for reading !!!
Please subscribe to my YouTube Channel for more video content by clicking here
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    Instead of rehashing up stuff that has been done 20,000 times already on every place conceivable on the internet , why don't you try and develop this to be adjustable properly and be finely polished so it turns on exactly when we want it on . None do and you know yours wont also .The rest above is just click baiting to earn you money
