How to Make a Simple PVC Car Camera Mount Rig
1,470
32
Posted
Introduction: How to Make a Simple PVC Car Camera Mount Rig
Have you ever wanted to mount a camera in your car so you could film yourself driving? Here is an easy and cheap way I discovered to for a hands free mounting setup.
[Watch Video]
Parts Needed (all 1/2-inch PVC):
- U-bolt kit
- 18 inch PVC pipe
- PVC Elbow
- 1.25 inch PVC pipe
- Custom PVC Camera holder (how to make video below)
- 1/4 inch drill bit
I first took a piece of 1/2 inch PVC and trimmed it to about 18 inches. This will allow the camera to be centered between the seats. I then marked the locations of the passenger headrest brackets using a permanent marker.
To make this work I purchased a u-bolt kit at a local store. It came with 2 u-bolts and all the hardware needed for about 2 dollars.
I then centered the u-bolts over the previous marks on the pipe and marked where the holes needed to be. All of the marks need to be inline with each other.
I first made a starter hole to prevent walking and then drilled a hole using a 1/4 inch bit. I did have to slightly widen the holes for the u-bolts to install easily.
Be careful if you have cloth near the drill because it can easily become entangled and hurt you. This was a close call but I was ok.
I then took the pipe and bolts to the car for a test fit. Everything slid into place and I used a 7/16 inch wrench to tighten the nuts. Do not over tighten the nuts or you can crack the PVC pipe.
To mount the camera, I could have drill a hole into the pipe and held the camera with a bolt, but that would have limited its mobility. So, I decided to use the PVC Camera Mount that I made in a previous video. I will put the link to this project in the description.
To attach the camera mount I needed a 90 degree elbow and a 1.25 inch pipe. I installed everything together and the camera fit perfectly into position. This setup will allow multiple angles of filming.
The mount did surprisingly well for being so simple. I did notice that there was a slight shaking at times while driving, but I contribute that to my tires needing to be balanced.
Overall I am very happy with how this project turned out.
Now I can drive and film and not worry about being pulled over by the police for using electronics while driving.
If you enjoyed this project click the Like button and tell us what you think about it in the comments.
We try to release a new video every week, so make to sure to click that subscribe button so you won’t miss out.
Have fun building.
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Epilog Challenge 9
    Epilog Challenge 9
2 Comments
Wow, That looks so much better than all of the IKEA lamp hacks :)
