Introduction: How to Make a Simple Tibetan Style Pearl Stranded Necklace With Multiple Gold Chains Linked
Are you seeking for easy and simple necklace designs? Here is a great suggestion – simple tibetan style pearl stranded necklace with multiple gold chains linked! The steps are listed below.
Step 1: To Make a Simple Tibetan Style Pearl Stranded Necklace With Multiple Gold Chains Linked, You Will Need:
10mm White Glass Pearl Beads
8mm White Glass Pearl Beads
Brass Rhinestone Spacers
Gold Cross Chains
Tibetan Style Toggle Clasp
Gold Jump Rings
Gold Bead Cap
Gold Headpins
God Eye Pins
Long Nose Plier
Round Nose Plier
Step 2: Make the Pearl Necklace Strand
1st, prepare enough 8mm white glass pearl beads and gold eyepins, thread a pearl bead through each eye pin one by one;
2nd, twist a small loop at each end of the eye pin, and connect the pearl beads with each other as shown;
3rd, connect the pearl beads to a proper length that fits you well.
Step 3: Add Tibetan Style Ornaments Designs
1st, pick a gold head pin, thread it through a 10mm glass pearl bead, a gold bead cap, a rhinestone spacer and a 8mm pearl bead in sequence, make a loop at the end of the headpin and hook to the end of the pearl strand as pictured;
2nd, attach a tibetan style clasp to the other end of the pearl strand;
3rd, cut several pieces of gold cross chain in different lengths, and hook them to the toggle clasp respectively;
4th, attach the other ends of the gold chains to proper position of the pearl strand as shown in the picture below.
Step 4: Time for the Final Look! I Like This Simple Tibetan Style Necklace Design! How About You?
If you're beginners in jewelry making, then this simple tibetan style pearl stranded necklace with gold chains linked would be a great choice for you to make a trial! I believe that you will do it well by following my instructions, good luck!
