How to Make a Simple Wireless Charging
5,006
76
8
Posted
Introduction: How to Make a Simple Wireless Charging
Inductive charging (also known as wireless charging) uses an electromagnetic field to transfer energy between two objects through electromagnetic induction. ... Energy is sent through an inductive coupling to an electrical device, which can then use that energy to charge batteries or run the device.
Step 1: Video
see this video if you like it you can make it
Step 2: Make a Simple Wireless Charging
To make a sample wireless Charging we need
1- NPN transformer (2N2220A)
2- 1Kohm resistor ()
3- copper wire
4- LED
5- 1.5v battery
Step 3: Coils
make a coil two coils
the first coil make 15 Turns and make a center tap then make more 15 Turns
the second Coil make 30 Turns
Step 4: Circuit
draw the circuit such as the photo
Step 5: Other
for test connect an LDE to the secondary coil and test it
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
6 Comments
Nice design !
Classical. This build is not efficient at all but fun to experiment. Simply take care that there's an alternative current on the secondary coil.
dear I said its is only a simple . before i build a DC to DC converter it the best efficiency for a make a good wireless charging.
In secondary coil if you use a diode and capacitor you can make a DC
For draw and montage.
I'm using both Adobe Photoshop and Adobe Premiere.
asalamualaikum.....good
Alaikuma salam wa rahmatullah wa barakathu.
Thank you
