iImage Information
I was cleaning out my room and managed to come across a lot of left over scraps from old projects that I have saved over the years with the intent of using them later. Usually, this means I organize the scraps and stash them somewhere to be forgotten until my room needs to be cleaned again. This time though I was simultaneously trying (and failing) to organize my thread, wishing I would cave and buy the expensive thread rack I never let myself get at the craft store. Very, very luckily it dawned on me that all the supplies I needed to make one were sitting right there in my pile of scraps. The thread rack I ended up with is small, flat, and can either be hung on the wall to save space or taken down to be laid flat at a work space.
Step 1Supplies and Tools
iImage Information
-Scrap wood (thick enough to drill through)
-Wooden dowels
-Fabric
-Quilt batting
Tools
-Pencil or marker
-Ruler
-Tape
-Drill
-Saw
-Sandpaper
-Staple gun
-Scissors
-Hammer
-Awl or a sharp tapered object
I had to buy the dowels but everything else I had around, including the silly rhinoceros fabric. I forgot to stagger my dowels, so it is a bit crowded but I figure I have enough of the skinny spools that it will still be useful. I had a drill press and set up a 45 degree guide as you mentioned. I couldn't get all the holes drilled that way, so I had to do some by hand. Those were not angled as consistently but it is not too noticeable. It is quicker to do by hand.
I had access to a belt sander which made rounding off and sanding the dowels easier. The biggest divergence from your design was I did not bother to 'dot' the fabric. I just put it on there (good instructions on how to get it tight!) and felt where the pre-drilled holes were and poked with an awl. I used glue on some and not on others.
So big thanks for getting me going on this -- I'd been wanting to do it and I liked how yours looked with the fabric & your re-use/re-purpose ethic is great.
However, I am going to use your idea as where I live now is temporary.
Covering is a good idea to keep dust off and thread from drying out. Easiest way to do that is go to a bakery and plastic cake covers, then make your spool holders to fit under the cover.
Seriously, I love the thread rack, probably also have all the tools and materials lying around somewhere, I just have to dig - and I do mean dig - through the three-car garage that has never seen a car in order to find everything! Thanks for the how-to.
Nicely done! I like the crafty addition of fabric and batting. Scrap wood is so easy to find, and if you want a fancy, uncovered wood block, check out your local reusable building center or ask around on FreeCycle.com. What I like most about your project is that the spool spacing can be easily adjusted to any spool size to optimize storage space. I also like tall spindles since I want enough space below each spool to hold two matching bobbins. I can also see creating several spool holders, arranged on a wall to create a decorative as well as functional object.
For the ones I built, I just used the board, sanded and stained - no covering required. The dowels were only about 2" long and drilled 1/4 to 3/8" deep.
Do not hang in sunlight, if you are an occasional user of thread, consider a cover (hinge a clear plastic container on top) thread will ge dirty and vintage thread needs extra care and actually does best in a refrigerator to retain moisture content and keep the thread from becoming brittle.
Seriously, though, I'd put some scrap wood under what you're drilling to stop yourself from drilling a hole through the carpet - not to mention getting saw dust pretty deep into the fibres.
It's nice that you can customize it for different spool sizes too.
