Step 6Attaching the Dowels and Finishing Touches
You can make these holes very easily with an awl, unfortunately for me, I had misplaced mine at the time and had to improvise with a needle tool (the kind you use with clay) and the drill. An awl is very easy to use and absolutely the best way to make holes in fabric to attach eyelets, but really any sharp tapered object like a large nail or a knitting needle should work just as well. It works by pushing the fabric's weave instead of cutting into the fabric in order to reduce fraying. If you have something like this, all you have to do is use it to push through the fabric.
Next, line up the tapered end of the dowel with the hole and hammer, and it in until it is snug and doesn't move. If it wobbles and isn't staying put and hammering it in harder doesn't work, try using wood glue.
If you really don't have anything like an awl, you can try it down and dirty with a large needle and a drill like I did. Start with puncturing the fabric with a needle. Change the drill bit to a much smaller size and very, very carefully drill into the fabric, while holding the fabric as taut as you can with your fingers.
After you get all the dowels in place you can staple a sturdy ribbon to the back or attach a picture wire so you can hang it on the wall. Load up all your thread, and Ta Da! You're done.
Here are some other ideas you might want to consider while making your thread rack:
-Use pencil stubs as dowels
-Paint or stain your rack instead
-Leave room for an area to put a thicker layer of batting to make a built in pin cushion
comment
Add Comment
Add Comment
