(MATERIALS)
1. venner (hard rock maple for the wood go to www.snowboardmaterials.com)
2. tiebond glue 3 ultimite glue
3. molded press
4. jig saw or band saw (if you have one)
5. router of rasp
6. spray paint & clear coat laquer
7. painters tape (blue)
Step 1: The venners
the next step is once you get the venners you will have three types of venners they are called
Face- which is a venner that is sanded on one side but not sanded on the other side that is the first venner.
Core layer- it's the same thing as the face but both sides of the venner are not sanded.
Cross band- which is a sheet of venner that is not cut with the grain but is cut going against the grain
This is how the venners are supposed to be layed
Face, Core layer, Cross band, Core layer, Cross Band, Core layer, then the last one is a Face
Step 2: Gluing the Venners
If you use any other type of glue beside tiebond your screwed because the other glue doesn't hold as strong as tiebond trust me I've done it before.
Any way for gluing process take a sanded side of the Face on the concrete or were ever you do this, and the unsanded side up. Put glue on the unsanded side of the face then take a core layer and put that on the face do that with the same thing as the cross band 7 times
Step 3: Pressing and curing
Take two pieces of cardboard that are about 3 inches wider and longer then the unshaped board.
then, put the mold on it's side and stick the venners between the mold and the cardboard, then take 2 4' channel irons and a about 20" to 16" bolts with nuts and washers. Now put the channel irons in the center of the mold so it gets a good nice press. once this is done let the deck take its shaped for about 1 to 1 1/2 days for it to cure good and strong
Step 4: Designing the uncut
Step 5: Cutting the uncut
when you do this I would just suggest to use a band saw because it's more accurate of a cut, but if you don't have one you can always use the handy dandy little jigsaw. when you star to cut make for cut I'll show you in the picture, start your cutting.
After you get done cutting it out take a router of a rasp to curve the edges ( thats to make sure you don't get slivers. after that is done sand the entire deck then take steel wool of sand paper ( about 150 to 220 grit) and hand sand till it's super, super smooth. oh don't forget to drill the truck holes
Visit Our Store »
Go Pro Today »
my question is...
How do you get or construct that skateboard mold ?
Thanks
I'll prbably try and make an instructable later on this year but for now got to a website called www.diyskate.com then once you get their click on diy skateboards and it give's you instructions on how to make them.
