3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Snorricam
The Snorricam, named after Einar Snorri and Eiour Snorri,or the "Snorri Brothers", is a body mount for a camera which is used to create an interesting point of view, which can be seen in such movies as I Am Legend, Slumdog Millionaire, The Hangover, and most impressively, Requiem for a Dream. I work for a small video production company, and with much enthusiasm from my boss, I designed and built my own version of the Snorricam, which is very adjustable and versatile. For about $30 in parts, and around a day of labor, You can have yourself an adjustable Snorricam of your own! Sorry for the lack of pictures, but i built it before I wrote this 'ible, but hopefully the Sketchup renderings will suffice.
ALSO: I am NOT responsible for dropped or broken cameras as a result of using this rig.  This Instructable is merely a guide to building a Snorricam, and should be adapted for your particular setup.  I suggest that if you build this rig, you test it with more weight than you'll be using before putting your precious camera on it.
For an adaptation on my design, check out HipHopSuperman's snorricam
Heres a video of me and the Snorricam in action.
And Heres a "behind the scenes" video of the setup we used for the above video.
Lastly, about 40 seconds into the video below, You can see the snorricam in action in our submission to the 48 hour film project in Portland, OR.
Step 1Tools and Materials
Tools and Materials
My design is fairly simple, and requires only a few simple tools. All materials can be easily obtained at your local home improvement store (Home Depot is our favorite) for around $30. That being said, the more tools you have, the easier this build will be.
Tools:
  • Drill with basic set of drill bits,
  • Handsaw,
  • Router with 1/4" roundover bit (optional),
  • Jigsaw,
  • Circular saw,
  • Hack saw with metal blade,
  • Sandpaper. I actually used drywall sandpaper cloth stuff, but use what you have around,
  • Compass with pencil attachment,
  • Small framing square (the kind with the lip and a 45 degree angle),
  • Tape measurer
Materials:
  • One 1"x3" @ 8' long,
  • 3/4" plywood (You'll need 3 pieces no larger than 12" x 8" each),
  • 1/2" plywood (a piece no larger than 8" x 6"),
  • Matching nuts, bolts, and washers(Use what you have, I didnt have to buy any new hardware when building mine),
  • 1.5" angle iron or angle aluminum,
  • Wood screws
  • Two 2-packs of Tiedown straps from Home Depot(~$7 each)
72 comments
1-40 of 72next »
Oct 5, 2009. 12:01 PMhiphopsuperman says:
After being inspired by this instrucable, I decided to make a snorricam of my own. If you wanna see my videos, here some of them are:
Check out my youtube channel for more! Thanks again CarterMarquis for the great tips!
Oct 6, 2009. 2:58 PMhiphopsuperman says:
Here you go! You motivated me to finally getting around to making an instructable! Thanks again for your great tutorial, it really helped me out for making my snorricam. Cheers!
http://www.instructables.com/id/How-to-make-a-snorricam-1/
Nov 29, 2010. 10:26 PMugman77 says:
A friend of mine and I just built this, great instructable! I am really happy with the results. We added some L brackets for extra support as well.
I really love your design for pivoting, really is a lot better than some other designs I have seen.
Nov 30, 2010. 2:01 AMugman77 says:
will do once my next project gets completed!
Aug 2, 2010. 5:21 PMmg0930mg says:
I love this. Already made mine, and made it so the head is adjustable. Very easy to follow, and takes an afternoon. I will post pictures and a video, soon hopefully.
Jul 4, 2010. 9:56 AMmg0930mg says:
Wonderful. I'm printing the instructions out now, and going to make this.
May 24, 2010. 12:37 PMlimez says:
so i made it, TWICE, the first was for a friend who gave me like $45 bucks to make it, but i had a slight problem with figuring out how to use the second elbow, but i just made holes at the other end of the lower arm and it is quite adjustable.  one question though, a friend of mine who is an amazing cinematographer, wants me to make him one, but he wants to have it so that it can go at different angles, like side to side i guess.  do you have any suggestions? please.
Apr 7, 2010. 2:45 PMPhysix21 says:
I dont understand this points :(.
Its inch, isnt it?
Can some one post it in cm?
Mar 21, 2010. 3:42 AMLaylasita says:
This is so neat, I am going to have this build for sure!
And your video is great,(you're really cute :D)
Feb 8, 2010. 11:44 AM916faith says:
Hi I just found this site and its great! I love your snorri cam but can it hold a camcorder under 6lbs?
Dec 10, 2009. 8:59 PMRebelApo says:
Hi. Is there annny way you can list all the measurements you have in the google sketch up documents, here? I've been trying forever to figure out what it says, because I keep getting confused by your directions. I'm an excellent copier however, and just really need to know these measurement before I pull all my hair out, lol.
Dec 11, 2009. 11:12 AMRebelApo says:
Ah! Thank you so much. I had to do some guesstimate work on the plates as well. Will definitely post pictures when done.
Jul 16, 2009. 11:18 AMz00110100 says:
Wow. Excellent. This is one of the best and most versatile DIY Snorricams I have ever seen. Fantastic!
Jul 16, 2009. 11:20 AMz00110100 says:
Great shirt in the test film too. :] Seriously though.
Aug 20, 2009. 7:40 PMmg0930mg says:
Don't know if you know, but indy mogul just did a new one, and I have to say yours is still the best.
Aug 20, 2009. 9:45 PMmg0930mg says:
Yeah, because they need that week or so in advance. I really like this, though. I believe this will be my first project when I move. :)
Aug 21, 2009. 10:50 AMmg0930mg says:
I will most likely have it done by halloween, if we move in time. :)
Jul 19, 2009. 6:08 PMz00110100 says:
No problem! I have to go find one of those shirts now, heh.
Jul 22, 2009. 12:51 AMadcurtin says:
This is a sweet instructable. Here's a tip for drilling holes in wood: if you're going all the way through, put another piece of scrap wood below the main piece, it will prevent the main piece from chipping out on the back side of the board.
Jul 17, 2009. 5:48 PMBomberkid says:
I thought this was an insturctable for video taping people who were snorring ( >_< FAIL). But it's still really cool sense I like to film a lot. I just never have enough time to make any of this kind of stuff.
Jul 15, 2009. 7:37 PMpurple shirted eye stabber says:
I have same camera. execpt with a bigger (better?(maby)) lens. p.s. i dont know the specs of the lens.
Jul 17, 2009. 2:06 PMpurple shirted eye stabber says:
well none the less your camera still has great quality. :)
Jul 16, 2009. 3:48 PMmappum says:
Opps, the link in my post below doesn't work. here's the link: http://www.youtube.com/watch?v=VshLGLVDPq4
Jul 16, 2009. 3:46 PMmappum says:
This must be how they did the gypsy scene in "The Red Violin". Here it is: http://www.youtube.com/watch?v=VshLGLVDPq4. The part I'm talking about is 55 seconds in.
Jul 16, 2009. 10:00 AMydma1796 says:
Excellent job, my son is a junior videographer. I think he would love it if I made him one of these.... 5 stars all the way
1-40 of 72next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:Cartermarquis
I like making things, and I like showing people how to make things.
